Nikasil
Old Oct 8, 2007 | 09:29 PM
biackbenz's Avatar
biackbenz
Default Nikasil
Someday I hope to buy a corvette, most likely a C5, maybe a C3. Have any Corvette engines been manufatured with a nikasil lining of the cylinders
Old Oct 9, 2007 | 01:54 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
????? A What! ???
Bc
Old Oct 9, 2007 | 01:58 AM
Skinny Kid's Avatar
Skinny Kid
Good question. Now if I can figure out what you're asking....
Old Oct 9, 2007 | 08:04 AM
Mac11's Avatar
Mac11
To the best of my knowledge "NO", that was entirely a BMW screw-up !!
Old Oct 9, 2007 | 08:13 AM
blazeone's Avatar
blazeone
Honda used it on the two-cycle motox motorcycle engines in the 90's. I'm not sure if they use it with the new four-cycle engines.
Old Oct 9, 2007 | 08:21 AM
vincentjames501's Avatar
vincentjames501
^^ Why do you say that? My friend drives a bimmer and he claims that ferrari's and them use this lining as well and he used to brag about it. What makes it so special.
Old Oct 9, 2007 | 10:45 AM
WKMCD's Avatar
WKMCD
It is a nickle silicon surface several thousandth's thick that was used on cylinder bores instead of an iron liner. Also used was a chrome alloy. The TZ's I used to build and ride used chrome bores on an aluminum casting. The purpose was to allow more direct heat transfer to the jacket. It worked well but scored easily and once scored you threw the whole set of cylinders away. Nickle silicon was tried as a resurfacing process but without a lot of success.
Old Oct 9, 2007 | 12:26 PM
TType85's Avatar
TType85
my 92 740i had the nikasil engine. Fortunatly it did not have a single problem in the 15K miles I had it (2003-2004). The high sulphur content gas caused big issues with these engines and BMW had to replace a lot of them.
Old Oct 9, 2007 | 10:37 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Learn something new every day!
Old Oct 9, 2007 | 11:06 PM
sideoiler's Avatar
sideoiler
Default nikasil coating
Yeah, If I remember correctly all the LT 5 's had the coating on the pistons .. or the clyinders ?
Old Oct 10, 2007 | 01:16 AM
white90conv's Avatar
white90conv
Jaguar used nikasil on their V8 engines in the 98-2000 time frame with disastrous results. The changed to iron liners around 2000.
Old Oct 10, 2007 | 06:28 AM
jabrun's Avatar
jabrun
Right, Zr-1's used it on the aluminum cylinder liners.
Old Oct 10, 2007 | 07:48 AM
Pumba's Avatar
Pumba
The Corvette Racing Team's C6.R engine blocks have Nikasil cylinders. They allow a 4.1875 inch bore.
Old Oct 10, 2007 | 08:12 AM
Mac11's Avatar
Mac11
I'll bet they don't use "pump gas" in the C6R's tho.
Old Oct 10, 2007 | 11:44 AM
Pumba's Avatar
Pumba
What does pump gas have to do with a block having Nikasil cylinders. If the engine's tune does not encounter detonation, I don't see a problem.
Old Oct 10, 2007 | 12:23 PM
white90conv
From my Jaguar experience, high sulfur fuel is the problem, the same as mentioned in one of the BMW posts above.
Old Oct 10, 2007 | 05:18 PM
Mac11's Avatar
Mac11
Pump gas IS the problem.
Old Oct 10, 2007 | 05:43 PM
UncleFodder's Avatar
UncleFodder
Beemer Trivia
The sulfur content in pump gas was causing the deterioration of the BMW V8's in various vehicles (5 and 7 series) due to the Nikasil material. My '95 540 was within the affected years. BMW for a period of time would replace the engine, which made use of Alusil instead. The symptom would be excessive 'blow-by' in the cylinders, which required a leak down test to diagnose properly.
/Beemer Trivia
To Nikasil
