Warped rotor, time to upgrade!
They do and DJ shows 2-3X's in his case
Rotors are consumable items if you track your car. Does not matter who makes them. I agree
IF cryo does work, and the NON BIAS evidence is still out on that, once a rotor is heated in a hard brake ( 1000* +) any cryo or heat treatment is not functional.
My point is if done correctly it is a good choice
QUOTE]
The cooling stuff will work with whatever rotor you are using so kind of a mute point.
