engine cutting out
Old Oct 8, 2007 | 11:26 PM
countryblue's Avatar
countryblue
Default engine cutting out
03 Z06...17,000 miles...1st 2nd gear run's fine...3&4th..not felt as much as heard..cutting out at 5000 + rpm...?????any thought's...thank's ....Gary....and i'm not getting any codes..
Old Oct 9, 2007 | 01:49 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you get any FLASHING "Check Engine Lights" when the problem occurs????????? You can check DTC on the fly! Next time it happens, immediately (safely) pull up the DTCs and see what is listed. I bet you see a P-0300 DTC.
BC
Old Oct 9, 2007 | 12:53 PM
countryblue
thank's for the reply!!...no flashing light's...But how do I pull up dtc while driving...please explain...thanks....all iv'e been doing is pulling up codes after run and get a (no codes) for pcm etc..I also have a Haltec.Bridge with a kN filter,checked connections and maf looks good...also had a dyno tune about a year ago,guy said the tune would last 80,000 mi....tried to call him on this prob...but he is out of business...
Old Oct 9, 2007 | 02:27 PM
jirasvet's Avatar
jirasvet
Sounds like you already know how to pull up codes. With caution while driving You hold the exact same buttons. It is easily distracting from watching the road.
Old Oct 9, 2007 | 09:05 PM
countryblue
no codes but took it to the shop..they said the noise(cutting sound in the pipes isnt an issue) but they were concerned with the pinging at wot through 4-5000 rpm....could be crappy calif.gas...
Old Oct 9, 2007 | 11:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Quote
"also had a dyno tune about a year ago,guy said the tune would last 80,000 mi....tried to call him on this prob...but he is out of business... "
Tunes don't have an expiration date or mileage
"tried to call him on this prob...but he is out of business... "
I wonder why!!!!!!!!!!
BC
Old Oct 10, 2007 | 09:57 AM
BigSexy181971's Avatar
BigSexy181971
How do you pull up codes? What two buttons?
Old Oct 10, 2007 | 11:08 AM
jirasvet's Avatar
jirasvet
# While holding "options", press "fuel" four times within a 10-second period
Old Oct 10, 2007 | 11:09 AM
KCJeff's Avatar
KCJeff
Hold down the Options button while hitting Fuel 4 times (within ten seconds). System will then cycle through codes.
Old Oct 10, 2007 | 11:10 AM
KCJeff's Avatar
KCJeff
jirasvet, you're too quick for me! :-)
Old Oct 10, 2007 | 11:32 AM
BigSexy181971
Great, thanks guys
Old Oct 11, 2007 | 07:47 PM
Marcs c5's Avatar
Marcs c5
Is you traction control on when this happens? If so, turn it off and try it...but be careful, it can get a little hairy! When I first bought my vette I had the same problem and some of the members here told me this was my problem. Sure enough it was the problem. A
To engine cutting out
