Programing Tire Sensors????
Old Oct 9, 2007 | 04:19 PM
creole's Avatar
creole
Default Programing Tire Sensors????
I just had Goodyear put in some new tire sensors. They got to the stage where it said Tire training but would go no farther. It wouldn't go to Learn front left etc. They couldn't use the meter or whatever it is to program the sensors so the service notice is still blinking. Anyone have an opinion as to why they couldn't get the job done? Mike
Old Oct 9, 2007 | 04:23 PM
BlackZ06's Avatar
BlackZ06
Because they're idiots ??????
Old Oct 9, 2007 | 04:33 PM
Corvette Don's Avatar
Corvette Don
Not a strong eneough magnet and/or they werent using a magnet at all because like the guy said above they are idiots. Plus if they didnt know what they were doing they could have broke the sensor upon installing the tires, its not hard to do.
Old Oct 9, 2007 | 04:38 PM
rws.1's Avatar
rws.1
Did they install the correct ones...?
It would seem to me that magnet strength would not matter it the DIC would not go into the mode that said learn front left...
Old Oct 9, 2007 | 05:04 PM
BlackZ06's Avatar
BlackZ06
Default Do it yourself
Go here for instructions on how to train the TPMS.
You can do it yourself if you have a strong magnet .... many people use a loudspeaker magnet .....
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Oct 9, 2007 | 05:28 PM
jarsdad1's Avatar
jarsdad1
And if we knew where you lived, someone might step in to help. Fill out your profile.
Old Oct 9, 2007 | 05:42 PM
87SAM's Avatar
87SAM
Does your key fob work? It uses the same receiver as the TPM’s. The correct TPM’s installed? There are 1997- 2000 sensors and 2001 – 2004 sensors. The special meter is nothing more than a contoured magnet. Most any magnet will work, I use a toolbox magnet on a stick type. It’s not the size of the magnet but how you use it. :o
Old Oct 9, 2007 | 06:40 PM
creole's Avatar
creole
How do I fill out profile?
Old Oct 9, 2007 | 06:41 PM
creole's Avatar
creole
No my fob does not work. I just bought the car in Jan. Really am a rookie. Mike
Old Oct 9, 2007 | 07:18 PM
BlackZ06's Avatar
BlackZ06
Near the top of the page is a dark brown /red band .... 2nd item from the left says "User CP" ... click on that and then on the next page select from the menu on the left ... "EDIT PROFILE"
Old Oct 9, 2007 | 07:19 PM
BlackZ06's Avatar
BlackZ06
OK ... first follow the steps in the link I posted above to put the car into TPM Training Mode .... can you get to the point where it says "Train LF tire" ????
Old Oct 9, 2007 | 07:30 PM
creole's Avatar
creole
The wrench at Goodyear said it will not get to the "
train LF tire. Key Fob does not work either
Old Oct 9, 2007 | 07:38 PM
BlackZ06's Avatar
BlackZ06
OK, 1st ... YOU try and get it in training mode ... just 'cause the Goodyear guy says it won't go there ... doesn't mean it won't.
2nd If it won't go into training mode .... check for Diagnostic Trouble Codes .... go here for instructions to display them ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
Write down the codes .... and then post in this thread .... be sure to post the ENTIRE code ... such as U1099H or C1234C
Pay particular attention for codes from the RFA module.
Old Oct 9, 2007 | 07:46 PM
creole's Avatar
creole
It will go into tire training mode, but no farther.
ICUALL's Avatar
ICUALL
Sounds like it may be a bad receiver for the keyless remote and TPIS system.
See picture...
Different part numbers for different years !!!
Old Oct 9, 2007 | 07:49 PM
BlackZ06's Avatar
BlackZ06
OK .... now that it says "Train LF tire" take a LARGE magnet and hold it over/at the air valve on the front left tire..... after a few seconds the horn should honk and the DIC display will tell you which tire to go to next .....
Old Oct 9, 2007 | 07:50 PM
creole's Avatar
creole
My invoice from Mid America motorworks says 97-00 sensor low tire pressure
To Programing Tire Sensors????
Old Oct 9, 2007 | 08:01 PM
BlackZ06's Avatar
BlackZ06
Those are the right ones .. see ... your profile says you have a 98 ... pretty cool ... huh ... ???
If you don't have a magnet to train the tires ... try training the key fobs ... instructions are in your owner's manual ... If you don't have a manual I can point you to a PDF version that you can look at and even print if you need to.
Old Oct 9, 2007 | 09:05 PM
creole's Avatar
creole
I love the car, just hope things like this don't keep happening. I am going to Phoenix Thursday for a week then to Vegas for a week. Probably get to it when I get back. I appreciate all the help from everyone. Mike
Old Oct 9, 2007 | 09:07 PM
creole's Avatar
creole
The guy at goodyear tried that but it wouldn't honk. I will mess with it some tomorrow, then get at it when I get back to IL. from out west in 2 weeks. Thanks Mike
