Exhaust installation question
Old Oct 11, 2007 | 09:25 AM
72TTop's Avatar
72TTop
Default Exhaust installation question
Am installing a Z06 (take off) exhaust on my '04 Vert.
Pretty straightforward except the instructions I have from a Corvette Fever article about dropping the stabilizer bar. I couldn't figure out what they wanted me to remove...but now I have figured that out but I have 2 questions.
They don't list the torgue specs in the article for retightening the bolts holding the stabilizer bar to the frame (they list PSI if you're using an air wrench...which I am not). Anyone have the torque specs (top and bottom bolt)?
Also, before i figured out what they wanted me to unbolt, I started looseing the bolts on the ends of the stabilizer bar, (that little 5 inch dogleg) only to realize that after many turns, they didn't actually "loosen"...they must be secured at a certain depth against the rubber bushing. Did I screw anything up by turning them? I think they just rotated as I thought I was loosening them?
Old Oct 11, 2007 | 09:29 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You'll be okay on the endlinks (Dog Legs ) if you look in the center of the "BOLT" you'll see an allen wrench (Or star Bit) center!
So you will use an allen wrench in conjunction w/a wrench open end or boxed your choice
As for the TQ specs for the sway bar brackets someone will need to chime in because I don't have that here with me!
Thanks,Matt
Old Oct 11, 2007 | 09:36 AM
72TTop's Avatar
72TTop
thanks Matt..yes, end links...(can you tell I'm a golfer?)... I thought i saw the star end...so i probably just rotated them and not actually loosened anything...no harm/no foul, right? as the article said I don't have to remove the end links.
Old Oct 11, 2007 | 10:04 AM
madmatt9471
YUP! You're good!
You just have to get the *** end up real high in order to change that exhaust!
Thanks,Matt
Old Oct 11, 2007 | 10:14 AM
72TTop's Avatar
72TTop
i have it on a lift...and managed to change the drivers side without taking the stabilizer bar loose...but the passenger side will NOT come out without moving the bar...
Old Oct 11, 2007 | 04:27 PM
72TTop's Avatar
72TTop
still looking for torque specs on the bolts...anyone?
Old Oct 11, 2007 | 05:13 PM
SDLS1Rider's Avatar
SDLS1Rider
According to LS1howto The top one needs to be torqued to 49 ft lbs and the bottom one is torqued to 70 ft lbs.
Old Oct 11, 2007 | 06:10 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
You need to remove the sway bar brackets only..and pivot the sway bar downwards...the exhaust will slide right out...i did mine a couple of weeks ago....very easy especially if it's on a lift....good luck..
Old Oct 12, 2007 | 10:04 AM
72TTop's Avatar
72TTop
Thanks everyone!!
Old Oct 12, 2007 | 10:24 AM
Bugaboo's Avatar
Bugaboo
Exactly! , that easy
Old Oct 12, 2007 | 11:09 AM
rws.1's Avatar
rws.1
you might need to remove the heat shield for the gas tank on the passenger side ....
Old Oct 12, 2007 | 11:36 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
If the car is an auto - this is a must.
The shield is a two-piece arrangement, and if you remove the whole shield, the tank is now dangling.....so be sure to only remove the rearmost portion of the heat shield panel.....
best regards -
mqqn
Old Oct 12, 2007 | 07:28 PM
72TTop's Avatar
72TTop
sure enough, i dropped the sway bar and still can't get it out. came back to the post and found the "heat shield" issue post. what's the heat shield look like? plastic? nuts/bolts/screws?
Old Oct 12, 2007 | 07:36 PM
hotwheels57's Avatar
hotwheels57
I find this comes in handy...
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
Old Oct 13, 2007 | 12:42 AM
allmee's Avatar
allmee
The correct numbers!
Old Oct 13, 2007 | 01:57 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi 72TTop -
Look at the passenger side, in front of the muffler - there is a metal pan held on by 10mm bolts.
Remove the two bolts holding the rear pan on and slide it rearward to pull the tab out of the slot on the forward portion of the shield.
Then your passenger side catback pipe will come right out of there.
best regards -
mqqn
Old Oct 14, 2007 | 04:20 PM
72TTop's Avatar
72TTop
Hey thanks for the gas tank Shield info. Before I took it off, I backed the car up clear to the end (tires not quite hanging over) and I had enough clearance to turn the catback enough to slide her out. Good news for anyone else with an Auto car...just back it up to the edge of the lift.
Old Oct 14, 2007 | 07:18 PM
lucky131969's Avatar
lucky131969
The service manual covers this in great detail. It has been a lifesaver for me.
To Exhaust installation question
