how does the oil life function work?
Old Oct 11, 2007 | 11:31 AM
mouschi's Avatar
mouschi
Default how does the oil life function work?
i just heard that our Corvettes have a function to tell us the oil life. How does it work? Is it accurate? I just bought it and the sticker says my oil change was due months ago, but I still have 1500 miles worth of driving left until the oil is bad. I would like to know what the Corvette has to say about it ... if it is accurate!
Old Oct 11, 2007 | 11:46 AM
timemender's Avatar
timemender
It takes into account many factors such as engine heat, engine speed, and engine load, all over time. It does NOT factor in dusty environments, so beware of this and change the oil long before the recommendation if operated in dusty environments.
Old Oct 11, 2007 | 12:01 PM
mouschi's Avatar
mouschi
it is garaged - is that considered a dusty environment?
Old Oct 11, 2007 | 12:13 PM
BlackZ06's Avatar
BlackZ06
NO
A dusty environment, for example, would be if you lived and drove in the Mojave Desert.
Old Oct 11, 2007 | 12:15 PM
jirasvet's Avatar
jirasvet
No
driving in the desert or sand
Most GM vehicles now come with oil life monitoring
Old Oct 11, 2007 | 01:05 PM
BlackZ06's Avatar
BlackZ06
Three things ......
1) RTFM ... the Owner's Manual is there for a reason. There are many many functions available in the car that you should learn about ... Competition Mode .... Oil Life Monitor .... programming user options through the DIC .... whatever.
If you don't have an Owner's Manual ... go here for a PDF copy. You can even print it out if you want to.
https://www.mygmlink.com/pdf/go2cont...01corvette.pdf
Your profile has a picture of a 2001 .. so I've pointed you to the 2001 version.
2) You should fill out your profile. Go to the top of this page and click on USER CP in the red/brown band. On the next page, on the left, select EDIT PROFILE.
3) To see remaining oil life, push the TRIP button for the DIC and continue to press TRIP until you see "OIL LIFE REMAINING 50%" ... or whatever percent yours actually shows.
Old Oct 11, 2007 | 01:15 PM
rws.1's Avatar
rws.1
It is accurate and you can run until it says 0... If fact you are fine if you change your oil within 500 miles of 0 life.
BUT most of us baby our cars and like to change the a lot more frequently that required. Personally I change mine every 5K miles. it usually shows something around 50% remaining oil life.
Old Oct 11, 2007 | 01:32 PM
vincentjames501's Avatar
vincentjames501
Every 4K for me with full synth.
Old Oct 11, 2007 | 01:44 PM
Oldvetter's Avatar
Oldvetter
Early years C5's used 10,000 miles as the maximum, but later years used 15,000 miles. The computer "subtracts" from this maximum.
I have a 1998 and have done oil analysis, I always have plenty (over 1,000 miles) oil life left at 0%. I change mine at 0% which is about 6,500 miles.
I also use Mobil 1 oil in all my other cars. I change them at 7,500 miles.
Old Oct 11, 2007 | 01:46 PM
TEXHAWK0's Avatar
TEXHAWK0
I go by the oil life monitor, and it comes out about 4,500 miles for me.
Old Oct 11, 2007 | 01:55 PM
VetteDrmr's Avatar
VetteDrmr
Originally Posted by Oldvetter
Early years C5's used 10,000 miles as the maximum, but later years used 15,000 miles. The computer "subtracts" from this maximum..
Sorry, it's NOT a mileage indicator. As mentioned above, it takes into account many parameters monitored by the PCM (which is why it doesn't measure dirt that gets past the air filter). I autocross and cruise mine, so the OLM goes to 0 somewhere in the 7-8000 mile range. A day at the autocross or Drivers Education events will knock off 20% or so, with very few miles (say less than 100) driven.
And, using a good full synthetic oil, you'll be in good shape at 0%. I personally change mine after it gets below 10%, just to get rid of the DIC message.
HTH, and have a good one,
Mike
Old Oct 12, 2007 | 08:35 AM
Oldvetter's Avatar
Oldvetter
Mike
I know that. I guess I should have said, "the computer subtracts from this number based on: rpm's and oil temperature (including a combination of these factors, e.g. rpms while under a certain temperature subtract more mileage, and higher rpms also subtract more mileage)."
Old Oct 12, 2007 | 09:37 AM
David426's Avatar
David426
Motor oils today far excceed what they did 20-30 years ago.. Especially the Synthetic oils... People over react and are brainwashed that you should only go 3000 - 4000 miles between changes... Trust your DIC.. Blackstone laboratories will do an oil analysis and breakdown a sample of your motor oil for a minimal amount ($25).. Mobil-1 Synthetics still have plenty of life in them with little breakdown at 7000 miles.. Its possible to accumulate moisture in the oil pan during the winter months or when the car sits for long periods, mainly the winter time in cold climates.. Make sure to park the car in the living room during winter months
Old Oct 12, 2007 | 10:00 AM
robvuk's Avatar
robvuk
The primary function of the OLM is that it counts engine revolutions. This is FAR MORE ACCURATE than counting miles. Trust it, use it and save money. The 3,000 mile oil change is a thing of the past. What's harder on the engine, 2,000 miles in second and third gear in the city or 10,000 miles on cross country trips? The OLM knows the difference. Counting miles tells you nothing.
Old Oct 12, 2007 | 11:39 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by David426
.... Make sure to park the car in the living room during winter months...
Old Oct 12, 2007 | 12:09 PM
danziger's Avatar
danziger
You laugh, but I used to do that with my motorcycle. Drove my girlfriend at the time nuts...
Old Oct 12, 2007 | 10:52 PM
Baron138's Avatar
Baron138
I change it at about 4000 miles. Some including the manufacturers of the car and oil say you are wasting your money and oil by doing this. I don't care though. For the same reason I wash and polish it all the time , I like the car!
To how does the oil life function work?
Old Oct 13, 2007 | 03:39 AM
RoccoC5's Avatar
RoccoC5
Hey, my bike's in the dining room right now!
Old Oct 13, 2007 | 07:48 AM
vettenuts's Avatar
vettenuts
The service manual also includes an "Annual Change" irregardless of miles or what the OLM says. I usually go by that as I don't put enough miles on the car to get near the 0% mark. On my daughter's Envoy (she racks up the miles) we usually do it when she gets down near 0% or thereabouts, more a matter of convenience and my time to change it at that point. Other thing to remember is the C5 and the Envoy hold a lot of oil. My wife's BMW also uses a 15K mile oil change (I do 7,500 on that car) but it too holds 7 qts.
Old Oct 13, 2007 | 10:03 AM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Trust your DIC
