Tire sizing question
Old Oct 11, 2007 | 10:42 PM
Mpwr's Avatar
Mpwr
Default Tire sizing question
Is it safe to have a 315/35/17 on a 9 1/2 rim? for drag use I know its not good for handeling because the side walls will bolge out...
Dan
Old Oct 12, 2007 | 10:52 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Dan
No it's not because the rim is not wide enough and the tire will bubble in the center and you'll actually loose a portion of your contact patch, which is the whole reason that you went with bigger tires in the first place.
Old Oct 12, 2007 | 11:48 AM
Mpwr's Avatar
Mpwr
Ok...the only thing that bothers me about using 17's for the track is that you are limited to either 275's or 315 theres nothing in the middle...will i be better off just using 275's with a 17" wheel or should i get 18's where i have more choices like 305,315,etc..? I would like to use stock Z wheels so im limited to either 9 1/2 x 17 or 10 1/2 x 18 whats my best option for what im trying to accomplish?
Old Oct 12, 2007 | 12:08 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Tire selection depends on how much power you put out and what your purpose is. If you're a dragger or road race guy, your wheel selections will be different because road race guys typically increase their brake size to get better stopping power.
I run 18 x 10.5 275/35/18's and 18 x 12 335/30/18's with PS2's on CCW Classics with 14" Wilwood Brakes.
I like the 18's for all around use. What are you going to use your car for ?
Old Oct 12, 2007 | 02:31 PM
Mpwr's Avatar
Mpwr
Drag use
Old Oct 13, 2007 | 10:20 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Drag use
I would look for a set of used drag radials on the for sale or FI section. There is always somebody selling a set.
Old Oct 15, 2007 | 12:01 PM
Mpwr's Avatar
Mpwr
ttt
Old Oct 15, 2007 | 07:44 PM
Mpwr's Avatar
Mpwr
ttt
To Tire sizing question
