Rearend Noise
Old Oct 13, 2007 | 12:34 AM
R1234's Avatar
R1234
Default Rearend Noise
Hello,
My 99 has developed a noise coming from the rearend. It has the stock rims and tires on it. It has 41,000 miles. I only hear it at slow speed when you make a right turn or left turn. It sorta sounds like a tire rubbing.
Any ideas before I take to a shop?
Thanks,
Bryan
Old Oct 13, 2007 | 12:37 AM
99ssconv's Avatar
99ssconv
Sounds like the normal needed rear diff fluid flush and refill. Donot forget the additive
Old Oct 13, 2007 | 12:39 AM
allmee's Avatar
allmee
Sound like it's gonna be your rear end. Either it is low on fluid or the additive needs to be added...........or drain the old & use Amsoil severe gear oil Which has an additive already in it!
Old Oct 13, 2007 | 12:41 AM
R1234's Avatar
R1234
Thanks for the quick reply! I've read some of the other threads of people having rearend issues. Hopefully the flush/refill will take care of it.
Bryan
Old Oct 14, 2007 | 12:23 PM
R1234's Avatar
R1234
Just an update. Flushed/refilled with gear oil and additive. Walla! No more noise! Thanks for the help guys.
Bryan
To Rearend Noise
