No Back-up Lights
Old Oct 13, 2007 | 09:21 PM
RedRiderZR1's Avatar
RedRiderZR1
Default No Back-up Lights
My backup lights don't work. When I use the key fob to "unlock" the car the backup lights don't come on with the rest of the lights. Also when I put the car in reverse they don't come on. Car is a '99 with 6 speed and I checked the fuse but it was good. Not sure what is wrong. Anyone have an idea where I should look now.
Thanks.
Greg
Old Oct 13, 2007 | 09:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Try the easy things first, check the bulbs.
Old Nov 4, 2007 | 06:34 PM
mythrpy's Avatar
mythrpy
Default back up lights
I am also having trouble, bulbs check out OK, switch tests out fine and fuse is OK. Have lights when I use the key FOB but nothing when I shift to reverse. Have a 2003 with a six speed. Anybody have any ideas?
Dan
Old Nov 4, 2007 | 09:48 PM
BELVIN20's Avatar
BELVIN20
More than likely the back up switch on the trans has failed. If fuse is ok the switch is the problem.
Old Nov 4, 2007 | 09:52 PM
corvettejoe98's Avatar
corvettejoe98
dude that so wierd I have the same exact year car and have the same problem and checked all that **** too and they still wont work.. except they come on when i start the car but not when i put the car in reverse. Does anyone know how to fix this its kinda pissing me off?
Old Nov 5, 2007 | 08:16 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Which switch have you checked? Most of the time, on an M6 it is the reverse switch on the trans itself. Very easy fix.
Old Nov 5, 2007 | 04:51 PM
corvettejoe98
what do you do to fix it i want to get mine working?
Old Nov 5, 2007 | 06:08 PM
screw991le's Avatar
screw991le
Change the switch on the tranny. Do a search for pics and info.
To No Back-up Lights
