Auto dimming mirrors
Old Oct 14, 2007 | 04:49 PM
army2000's Avatar
army2000
St. Jude Donor '11
Default Auto dimming mirrors
Hello folks,
I was thinking of changing my OEM mirors to the auto dimmers. I know this can be done, but does anyone know the procedures and have the directions. Thanks.
army2000
Old Oct 15, 2007 | 08:10 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Check out this thread: http://forums.corvetteforum.com/show....php?t=1832490
Should be everything you need.
Old Oct 15, 2007 | 07:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Doing the outside drivers mirror requires a large harness change.
Old Oct 15, 2007 | 08:51 PM
'VETTE PHASE
Oops, I misunderstood. :o
Old Oct 16, 2007 | 04:28 AM
army2000's Avatar
army2000
St. Jude Donor '11
Thanks for everyone's help!!
Old Oct 16, 2007 | 12:06 PM
waupachino's Avatar
waupachino
If you are talking about the interior rear view mirror, I would be cautious about changing this out. I had an auto dimming rear view mirror in my Pontiac GTP, the thing started leaking the fluid that is inside of it all over the console and shifter plate. What a mess and you can't get the substance off after it dries and the mirror looked like it was fogged over. This is a very common problem with the auto dimming mirrors. Check out this thread before you go any further. http://www.clubgp.com/newforum/tm.as...de=&s=#3843208
Old Oct 16, 2007 | 07:42 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i don't think i've ever read a post on that happening in a c5 though...
Old Oct 17, 2007 | 11:18 AM
waupachino's Avatar
waupachino
I know it was the Magna Donnelly Mirrors that were the problem, I don't know what the C5 uses, but just wanted to make the OP aware if that is what is intended on being installed. They were installed in many makes/models.
On a positive note Magna Donnelly did replace my mirror as a pro bono good will gesture, but I opted not to install it because I had already replaced the mirror with a standard one and have 5% tint on the back window, so the mirror was useless anyway. Didn't want to take a chance on it leaking again either.
To Auto dimming mirrors
