ATTN: A C5 Tech!
Old Nov 14, 2001 | 10:57 PM
TLewis4095's Avatar
TLewis4095
Default ATTN: A C5 Tech!
I have a P1416 AIR System Bank 2 error code and it reapears after reset...any ideas on possible cause & fix? Seems to run fine & is consistant at the strip, but still want to correct it.
Thanks in advance! :yesnod:
Old Nov 14, 2001 | 11:14 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: ATTN: A C5 Tech! (TLewis4095)
let's get that straightened out before Sat....I don't want any excuses :jester .....btw, I'm not eating starting Thursday. The vert's 2 lbs heavier than the coupe right :lol:
Old Nov 14, 2001 | 11:16 PM
TLewis4095's Avatar
TLewis4095
Default Re: ATTN: A C5 Tech! (Mean Green 2000)
:lol: My trick is have less than an 1/4 tank as well!!! :lol:
Old Nov 14, 2001 | 11:18 PM
davidfarmer's Avatar
davidfarmer
According to themanual, there is probably a blockage in your AIR system, keeping the emmisions pump from pumping fresh air into one side of your exhaust system. You should probably check to see if air is being pumped into the exhaust manifolds by pulling the hoses loose while the vehicle is idling in closed loop mode. If you can verify that you are inded getting fresh air on both sides, then it could be an O2 sensor problem.
Basically, the car should run leaner with the AIR pump on than when it is off, and that is not happening on one side (not sure which one).
Dave
Old Nov 14, 2001 | 11:30 PM
TLewis4095's Avatar
TLewis4095
Default Re: ATTN: A C5 Tech! (y2khardtop)
Thanks Dave! I'll try it.
Old Nov 14, 2001 | 11:34 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
I got to looking at that mod list....maybe I'll throw some wires and the tsat in before then :D
Old Nov 14, 2001 | 11:41 PM
MDT's Avatar
MDT
TLewis4095,
Without going to the service manual.....I'd guess that the check valve on the right bank needs to be replaced.
Good luck.
Mark
Old Nov 15, 2001 | 05:26 PM
TLewis4095's Avatar
TLewis4095
Default Re: ATTN: A C5 Tech! (MDT)
It was the check valve...had to remove the intake to get at it!
Thanks all for the help!
:cheers:
To ATTN: A C5 Tech!
