Pilot bearing position - need advice
Old Oct 15, 2007 | 11:16 AM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Default Pilot bearing position - need advice
We're putting a clutch in my 98. The pilot bearing has one side with a race showing and the other has a solid surface. Does it matter which side faces the torque tube? We damaged one already when replacing the torque tube and it seems that the solid side (which has a slight bevil to it would be the appropriate side, but we believe that the race side was the factory installed side facing the torque tube. Also the bearings are not centered inthe pilot bearing, and are closer to the race side, which I would think you would want closer to the trorque tube. However, the beviled side would make realignment of the torque tube shaft easier. Any help or advice is appreciated. Thanks Zuti
Old Oct 15, 2007 | 12:00 PM
jirasvet's Avatar
jirasvet
Cajundude has a how to section on clutch install and how they feel about
pilot bearing install
http://www.cajundude.com/dopeinstall.doc
http://www.cajundude.com/c5techhome.htm
