Compression
Old Oct 15, 2007 | 11:17 PM
Clintny25's Avatar
Clintny25
Default Compression
If i think I have bad rings and i check the compression on my 03 Z06 what should it be at in a good range and a not so good range
Old Oct 16, 2007 | 01:05 AM
Third Gear's Avatar
Third Gear
The compression tester usually gives you a range of what is good and not so good. Consistency is more important than the actual values. I would say anything from 160+ would indicate a healthy engine. Anything lower than 140 or so and I would be worried..... A leak down test is handy tool as well. If adding a little bit of oil improves the test then it's the rings.
