cam size?
Old Oct 16, 2007 | 07:48 AM
Clintny25's Avatar
Clintny25
Default cam size?
Would you say that this is a mild or large cam? or is there better for the Z06
LPE CAM 234/240 duration @ .050 .598/.608 with 1.7 114.0
Old Oct 16, 2007 | 08:37 AM
AU N EGL's Avatar
AU N EGL
That is a large cam. With that duration and lift you may have some piston to valve clearance issues.
Better or best? depends on what you want you car to do, or a DD ??
Old Oct 16, 2007 | 08:39 AM
fsuforever's Avatar
fsuforever
That Cam Is No Slouch ,If i Have to categorize cams this cam goes to the Large Section ,Isnt this what your Running in your Car ?,btw i Ran a Slightley Bigger cam than that in my Stock cube motor & had no Ptv clearnce issues
To cam size?
