Help With a Code Please.
Old Oct 16, 2007 | 08:47 AM
rpm462's Avatar
rpm462
Default Help With a Code Please.
I'm intermittently getting a B2860 Telescoping Column Position Sensor Failure code. It always has an "H" at the end when I pull it up and it's also always in conjunction with a U1160 Loss of Comm with LDCM also a history code as well. This happens about once a week or so, and it resets fine. Any idea what's causing this? Everything is working fine as far as I can tell, but do I need to be on the lookout for something getting ready to break?
Old Oct 16, 2007 | 09:11 AM
vincentjames501's Avatar
vincentjames501
Blah, I would just forget about it. I have codes that get pulled all the time for my blinker, and my power seats. They work just fine... the computer is dumb. I also pull H codes for my HVAC but ac works just as good as new.
Old Oct 16, 2007 | 09:14 AM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
PM Bill Curlee and ask him. You may have a short somewhere that is causing the issue. Bill is the electrical guru on here and will probably know the fix immediately.
Old Oct 17, 2007 | 01:25 PM
rpm462's Avatar
rpm462
Thanks...read one of his posts which may suggest a bare wire in the door frame bundle... will check that out this weekend.
To Help With a Code Please.
