When should the clutch engage?
Old Oct 17, 2007 | 02:41 PM
BUGZ's Avatar
BUGZ
Default When should the clutch engage?
Did the Ranger flush yesterday. It only took two cycles before the fluid was clear. The pedal still seems low. Where in the clutch pedal stroke should the clutch engages / disengage? Mine feels like it is approx 2/3 inward, or ~1/3 up from the floor. I'm use to within the first 1-2 inches of depression. FYI Previous owner put in a new GM LS7 clutch. This is my first C5, just bought it less thatn 2 weeks ago.
99 FRC
BUGZ
Old Oct 17, 2007 | 02:53 PM
Oldvetter's Avatar
Oldvetter
Mine engages closer to the top. Probably 2-3 inches from top. 98 Coupe.
Old Oct 17, 2007 | 03:47 PM
MrLeadFoot's Avatar
MrLeadFoot
Mine seems like a long throw sometimes, but starts at about 1/2 way from the floor.
Old Oct 17, 2007 | 04:50 PM
waddisme's Avatar
waddisme
Mine seems to be about 3/4s of the way up.
Old Oct 17, 2007 | 07:15 PM
Old Rotor Head's Avatar
Old Rotor Head
I have the LS7 also and it's about the same as yours
Old Oct 17, 2007 | 08:10 PM
BUGZ's Avatar
BUGZ
Thanks for your input...sounds like there is no consistancy or anything to worry about...just keep the fluid clean.
BUGZ
Old Oct 17, 2007 | 08:46 PM
MrLeadFoot's Avatar
MrLeadFoot
Oops, my bad. Just checked. My clutch begins to engage about 1/3 from the bottom, just like yours.
To When should the clutch engage?
