spacers required
Old Oct 18, 2007 | 11:54 AM
yakisoba's Avatar
yakisoba
Default spacers required
I've got a set of weird tires, but I paid for them, so I'd like to use them.
They are Kumho V710 335x17. They fit on old GS offset rims, 17x11". The hitch is that they won't fit on the car! The tires rub on the inside of the wheel well. It's not lowered, so the outside of the fender is not an issue, but I need to run a spacer to allow the tires to go on. The question is what spacer (how much) and will I have to do wheel studs to fit 'em on? Thanks.
Old Oct 18, 2007 | 07:25 PM
yakisoba's Avatar
yakisoba
anyone?
Old Nov 19, 2007 | 03:43 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
test with half inch washers
Old Nov 19, 2007 | 03:47 PM
jbauch357's Avatar
jbauch357
yep, keep adding washers until you know the thickness of spacer required to fit the tires on. at the same time look at your lug nuts and make sure that all the threads are occupied with wheel stud - if not youre going to need longer studs too...
might not be worth it in the long run - you could sell the tires and put the money towards something that fits...
Old Nov 19, 2007 | 03:49 PM
AU N EGL's Avatar
AU N EGL
I got my 3/8" spacers from CCW
Summit Racing has spacers too
Old Nov 19, 2007 | 04:19 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I got my spacers from Thunder Racing.
Old Nov 19, 2007 | 04:21 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
up to 3/16 you should be ok without longer studs. if you need more consider longer studs.
Old Nov 19, 2007 | 05:08 PM
AU N EGL's Avatar
AU N EGL
Yes
I also run the longer APR studs and hardened lug nuts
To spacers required
