Need help with front bumper brackets
Old Oct 18, 2007 | 12:39 PM
C5TORCHED's Avatar
C5TORCHED
Default Need help with front bumper brackets
I am putting the font fenders and front bumper back on my 98 vert. I have the R & L angle brackets(w/studs) that go inside each fender(on the front). Then I have the R & L angle brackets that go inside the front bumper. So the brackets bolt the front fenders to the front bumper. Now the question is-- are there brackets that bolt the front INNER fenders to the front bumper??? I saw someone on flea bea selling what they claimed to be 2 front bumper brackets. They were about 10-12 inches long and about 1" wide, not sure where these would go and if I need them.
Old Oct 18, 2007 | 01:34 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The inner fenders bolt to brackets that the headlights pivot on.
They do not bolt to the front bumper cover at all that I'm aware of.
Old Oct 18, 2007 | 04:00 PM
C5TORCHED's Avatar
C5TORCHED
Maybe I am explaining this wrong. In front of the front tires- looks like 3 screws go through the outer wheel housing(of the inner front fender) and into the front bumper. Is there brackets for this??
Old Oct 18, 2007 | 09:12 PM
Point & Shoot's Avatar
Point & Shoot
There is a triangular bracket with 3 threaded studs on it that goes inside the front (bumper side) of the inner wheel house - the studs poke thru the 3 holes and the headlight assembly mounts to those studs with nuts.
Hope this helps - a bit hard to explain.
To Need help with front bumper brackets
