Help with DTC 0455
Old Oct 19, 2007 | 09:24 AM
Retof's Avatar
Retof
2nd Gear
Default Help with DTC 0455
My C5 6 Speed threw a Check engine light. I borrowed a Predator and found DTC 0455, however I have not been able to find it on the look-up list. The full description of the error code stated "Evap Control System (Gross Leak) Leak Detected". If anyone has any suggestions and corrective action please advise.
Old Oct 19, 2007 | 10:08 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Gas cap likely wasnt tightened all the way.
Old Oct 19, 2007 | 11:58 AM
BlackZ06's Avatar
BlackZ06
First, you should post the full DTC .... the starting letter (P,C, etc) tells if it is a Powertrain (P) code, and because it is possible to have multiple codes with the same number (P1234, B1234, C1234) .. also post the C or H listed at the end of the code (or both if listed).
You don't need a scanner to read the codes from a C5 Corvette .....
https://www.corvetteforum.com/techti...D=26&TopicID=1
In fact the car will display codes from systems like the SDM that a Predator (and most every other scanner) can't read.
Old Oct 19, 2007 | 01:09 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Gas cap !!!!
Old Oct 19, 2007 | 01:45 PM
trussme's Avatar
trussme
It can only be a P0455..."missing gas cap or tighten gas cap "at least 3 clicks" Or buy a new one...
To Help with DTC 0455
