Help...C5 problems
Old Oct 23, 2007 | 03:51 PM
KC2576's Avatar
KC2576
Navigator
Default Help...C5 problems
I have an 02 Black C5 with 35k miles. Here lately I have encountered some problems. I never used to do this but every time i start the car up the wiper blades come on and wont stop for like 10 mins. The passenger window wont let down and the the radio sometimes resets itsself..meaning I can have it on a station and it will be on another am station when i turn car on or if i leave radio on its off when i start the car. Anyone else had any similar problems if so what it your advise on fixing it before i take it back to the chevy place? Could it be a fuse or something?? any responses greatly appricated
Kc
Old Oct 23, 2007 | 03:53 PM
fastfb350's Avatar
fastfb350
Call a priest, your car sounds possesed!!!
Is there any aftermarket type of wiring in your vette? It sounds like there is some questionable wiring, maybe a short of some sort, going on.
Old Oct 23, 2007 | 04:05 PM
DeeGee's Avatar
DeeGee
Worth filling out your profile so members can target advice to your car
Is the battery the original. random electrical gremlins can be battery related. has a battery leaked and caused damge to any wiring. AC Delcos are renowned for leaks. If it gets into the wiring below the tray it can cause no end of problems. Worth pulling the battery to check all is well.
Old Oct 23, 2007 | 04:12 PM
hotwheels57's Avatar
hotwheels57
I don't know if C5/Z06 Corvettes have "actuators" in them like other GM vehicles (body control module?). Our Trailblazer recently started having weird electrical issues. Dealership said the newer vehicles are loaded with these "actuators" that perform multiple functions...seat memory, windows, mirrors, radio memory, etc.
In our case, there was also a definite wood pecker sound coming from beneath the instrument cluster, which was apparently an indication of the thing going bad.
Old Oct 23, 2007 | 04:16 PM
KC2576's Avatar
KC2576
Navigator
yes the battery had never been changed ..same one that came with it...if it is a leak that is causing these problems how much do you think to fix the wiring problems?
Old Oct 23, 2007 | 04:22 PM
KC2576's Avatar
KC2576
Navigator
no aftermarket wiring has been done to the car.. and i hope its not possesd lol
Old Oct 23, 2007 | 04:25 PM
hotwheels57
Does the DIC show any codes?
Old Oct 23, 2007 | 05:14 PM
KC2576's Avatar
KC2576
Navigator
i ran to see what codes came up and ironically the passenger window now is letting up and down..it hasnt in months.. here are a few codes i got
99-HVAC B0361 H
A0-LDCM B2284 H
A1-RDCM B2283 H B2265 H
58-SDM B0026 H
Old Oct 23, 2007 | 05:38 PM
hotwheels57
Those are all history codes as you're probably aware of...nothing with a "C" to indicate current codes?
If everything is working again now, maybe that is an indication of a bad ground.
I wish I know more about the codes...maybe member Bill Curlee will chime in. He's the recognized electrical guru.
Old Oct 23, 2007 | 05:46 PM
KC2576's Avatar
KC2576
Navigator
yeah i appricated all your help...its still not all working i cant get the window blades to stop ..but the passenger window is now working like i said it hasnt in months.
Old Oct 23, 2007 | 06:06 PM
hotwheels57
Below is Bill Curlee's profile page. I'm sure if you sent him a PM or e-mail (upper right side, "contact info"), he'd be happy to help you.
Hopefully, he'll post his suggestions here so we all benefit.
http://forums.corvetteforum.com/member.php?u=21968
Old Oct 23, 2007 | 06:18 PM
Oldvetter's Avatar
Oldvetter
My guess is your wiper motor is submerged in water. Clean your udders, do a search.
Old Oct 23, 2007 | 07:33 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would check out a new battery.
Does your vette have the memory option ? If so that is why the radio station changes it remembers your settings based on the key fob used.
If you have auto air it will also adjust that the seat and steering wheel.
Old Oct 23, 2007 | 07:48 PM
PFMC3's Avatar
PFMC3
Does the telescopic wheel work?
Does the memory function work?
Please list everything that does not work or is intermitant.
Old Oct 23, 2007 | 07:49 PM
PFMC3's Avatar
PFMC3
1ST
REPLACE BATTERY AND LOOK FOR ACID LEAKAGE UNDER BATTERY!!!!!!!
Old Oct 23, 2007 | 08:23 PM
KC2576's Avatar
KC2576
Navigator
yes the memory setttings work for steering wheel and seat
Old Oct 23, 2007 | 08:59 PM
fsuforever's Avatar
fsuforever
To Help...C5 problems
