which gears
Old Oct 23, 2007 | 08:22 PM
30th290's Avatar
30th290
Default which gears
i have a 97 c5 i just traded for my 89tta.it has a built ls1,dyno tune
Thunder Racing TRak cam 231/234 .640/.590 112 LSA. The heads on the car are PRC LS6 Stage 2 ported heads.dynoed at 403rwhp.my ? is the vette has 315 gears and i think i should go with a little taller gear for that cam.any suggestion.373,390,410 pros and cons please.
thanks jim
Old Oct 23, 2007 | 08:47 PM
TLewis4095's Avatar
TLewis4095
Need to know your tranny & just what you intend to do as far as driving/drag racing/autocross, etc.
Old Oct 23, 2007 | 08:55 PM
30th290's Avatar
30th290
my trans is a built 4l60e stage 3 good for 650hp with a 3200 yank converter.the car had a 4000 stall when dynoed but it was to much for the street. i plan on taking to the 1/4 mile on weekends every now and then.
Old Oct 23, 2007 | 09:15 PM
AlisonC5's Avatar
AlisonC5
3.42s or 3.73s are popular choices for AT cars.
Old Oct 23, 2007 | 09:26 PM
TLewis4095's Avatar
TLewis4095
I run 3.42's in our bracket car (mid-low 11's on motor). 3.73's would be the ultimate, but highway driving will suffer a bit.
Old Oct 24, 2007 | 09:29 AM
30th290's Avatar
30th290
would the 373 make a big differance from the 315 gears.
Old Oct 24, 2007 | 11:31 AM
TLewis4095's Avatar
TLewis4095
Huge on an A4.
Old Oct 24, 2007 | 11:35 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Originally Posted by TLewis4095
Huge on an A4.
yep, go 3.73 youll love it
Old Jan 22, 2008 | 12:09 AM
WildTurkey's Avatar
WildTurkey
If you go from 315 to 373, and you are only really driving on the street, is it strongly recommended to replace the stock converter (and if so 3000, 3200, 3600, etc.)??
Old Jan 22, 2008 | 06:09 AM
Oldvetter's Avatar
Oldvetter
Rear end ratios
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
G90 Axle, Rear, 3.15 Ratio
One other way. Drive in 3rd gear (automatic trans) at 75 mph on level ground, look at your rpm's. If your turning 3150, you have 3:15's. If you're turning 2730, you have 2:73's. Just move the decimal over to the left 3 places.
. Or... place your A4 into third gear and get on the highway. At a constant 75mph (making sure the TC has locked) read the rpm value; then divide it by 1000.(This also works with the six speed manual transmission using 4th gear):
examples:
2730 RPM........ you have a 2.73
3150 RPM........ you have a 3.15
3420 RPM........ you have a 3.42 (not a factory available ratio with the A4)
3730 RPM........ you have a 3.73 (not a factory available ratio)
3900 RPM........ you have a 3.90 (not a factory available ratio)
4100 RPM........ you have a 4.10 (not a factory available ratio)
(assuming rear tire height has not been altered from the factory height)
To which gears
