Time for some heads.
Old Oct 24, 2007 | 10:42 PM
MJD's Avatar
MJD
Default Time for some heads. **Update-numbers at bottom**
Decided to take it up a notch and add a set of heads. Mike Stark @ CFM is currently working on a set of 241's for me. I'll be picking them up this Saturday. I'm having them flowed, it will be interesting to see what they'll do. Port work has been done on intake and exhaust, and a valve job with valve profiling. Here's where I'm at tonight:
Old Oct 25, 2007 | 12:34 AM
bgreen83's Avatar
bgreen83
how long did it take you to remove everything?
Old Oct 25, 2007 | 06:35 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Ae you going to clean up your pistons while you have it open? Is that even a good practice?
Old Oct 25, 2007 | 09:38 AM
MJD's Avatar
MJD
It took about 6 hours to get everything out. The longest part of the job was pulling all 30 head bolts. Overall there was nothing difficult about the job. And no, I won't be cleaning my pistons. They're not even that bad and IMO it's a waste of time.
Old Oct 25, 2007 | 07:51 PM
tompugh's Avatar
tompugh
Hello, What are the specs. on the heads and what cam are you running? Are you planning to replace the lifters and push-rods while you are in there? Stock exhaust or are you running headers (I assume). Do you plan on getting it tuned after the new heads are on? What are your goals for the engine and car? Thanks for sharing. Tom
Old Oct 25, 2007 | 08:04 PM
noahdr's Avatar
noahdr
good luck with the project
Old Oct 25, 2007 | 10:19 PM
MJD's Avatar
MJD
I'm not sure what the head specs (flow data) are yet since I don't pick them up till Saturday. I'll post some numbers when I get them. They are a stock 241 casting with stock valves. I'm doing an exchange so I'm just paying for port work. A fellow forum member recommended CFM so I thought I'd do something different from everyone else and give them a shot. The money I saved by not going aftermarket went toward picking up parts such as ARP head studs. I'm running a vinci XXX cam, 222/228 .551/.551 115. My other mods are in my sig. I've got a set of caddy racing lifters going in and I've already been running a set of trick flow rods. I'm going to port the throttle body, descreen the MAF, add SVO 42# injectors, and also do the ls6 PVC conversion. My tuner is Chad Rose a Greenlight Motorsports and the car will go on the dyno when done. This is basically a street car that will make it down the strip once and awhile. It's simply my toy and hobby.
Old Oct 28, 2007 | 10:27 PM
MJD's Avatar
MJD
Picked up the heads today and have some flow numbers to share. Again, these are stock 241's with stock valves. The exhaust has been fully ported but the intake has only been touched up at the opening. The intake does not have a full port. And the results are:
lift in ex
.100 77 65
.200 145 116
.300 199 159
.400 243 190
.500 275 210
.600 285 216
Old Oct 28, 2007 | 11:28 PM
uracowman's Avatar
uracowman
Ls1
Old Oct 29, 2007 | 07:59 AM
deathinnovember's Avatar
deathinnovember
Looks like a solid street machine man.
What kind of horsepower ratings are you shooting for?
Old Oct 29, 2007 | 08:40 AM
MJD's Avatar
MJD
I'd like to see 420 to the wheels. I think a dyno tune and these heads will get me there. The numbers I'm putting down right now (377/358) are with an 11:1 AFR.
Old Oct 29, 2007 | 09:12 AM
deathinnovember
I could be just a n00b. But what made you go with such large injectors? It seems a big over kill for 420rwhp.
Old Oct 29, 2007 | 09:23 AM
AU N EGL's Avatar
AU N EGL
any reason you Ported the 241s vs buying 243s or PP 243s?
I ported my 241s then took them off an put on stock 243s with 224/224 585/585 112 lsa and I am just over 400 to the ground.
I have some LPE SWGT PP 243s with a bigger cam to go on this winter, and hoping for 440-450 to the ground
Old Oct 29, 2007 | 09:39 AM
MJD's Avatar
MJD
I wanted to try something different from everyone else. CFM has a great reputation so I wanted to give them a try. Price was another factor. The money I saved allowed me to pick up other parts. It worked out great since these flow very well. I can always pull them down the line, have the intake fully ported, and add bigger valves for more power.
Old Oct 29, 2007 | 09:42 AM
MJD's Avatar
MJD
I'm thinking forced induction or nitrous down the line. I picked them up used and couldn't pass on the price.
Old Oct 29, 2007 | 09:43 AM
deathinnovember
Oh definitely I wasn't sure. I might go down that line also. Why not knock out two birds with one stone.
Old Oct 29, 2007 | 09:44 AM
AU N EGL's Avatar
AU N EGL
Ok Kind though that was it.
The biggest thing I notice with my pp 241s were they are very quick off the line and up to 4000 rpms, so I tuned my car for low end tq vs high end HP
Good Luck on your project and let ppl know how things turn out
To Time for some heads.
Old Nov 25, 2007 | 12:44 PM
MJD's Avatar
MJD
I am bringing this thread back from the dead to post numbers. Had the car tuned by Ron at Pro Dyno Tech on a Dynomite dynometer. And the results are:
Old Nov 25, 2007 | 02:39 PM
bdiddo's Avatar
bdiddo
Those are some really nice numbers. I am very interested in learning more as am about to start rebuilding an LS1 this winter. How is low your end ? My initial research indicates that 241 heads only stand up to but so much porting. I am looking to set up the heads for street/strip and want strong low end (don't care much about top end). The cam in it (MTI Stealth) is very close to yours and with the tune I had on it, it really kicked in at low RPM (around 2100 RPM) and pulled strong up to mid 5K. Probably will have to change cams but that's another story. My current numbers are ditto yours- pre-head work. I would be very happy with your results if I could achieve it with head porting my 241's.
"live by a quarter mile at a time"
Old Nov 25, 2007 | 03:09 PM
MJD's Avatar
MJD
The low end feels better than stock and once I get to about 3000 it really starts to pull. From what I understand the cam determines the powerband more than heads. The runner was kept small to help air velocity which if I remember correctly helps add torque.
