Okay Need some Help Code PO135
Old Oct 27, 2007 | 12:12 AM
04tripleblkcoupe's Avatar
04tripleblkcoupe
Default Okay Need some Help Code PO135
Just did a Long tube headers and cats,company sent the wrong adapters for the 02 sensors, first codes were PO134,PO135, got the new adapters today installed the driverside adapter and I am only getting the PO135 code now, any suggestions on a fix ?
Old Oct 27, 2007 | 12:16 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Did you have your car tuned after the install?
Old Oct 27, 2007 | 01:51 AM
jirasvet's Avatar
jirasvet
Do you have scan tool software?
It would be easy to trouble shoot if you had scan tool to monitor HO2s.
Any way read this link.http://www.gearchatter.com/viewtopic10479.php
sounds like a damaged sensor
Old Oct 27, 2007 | 08:40 AM
04tripleblkcoupe
Had a tune after the install,going to check out the things listed to see if I can track down the problem, thanks to all the response.
Old Oct 28, 2007 | 01:38 PM
04tripleblkcoupe
Okay just checked the scanner and shows where thereis no activity on the 02 sensor, being a 04 I read where it has 2 types of 02 sensors who knows the part # to the rear sensors (GM Brand) ?
Old Oct 29, 2007 | 02:29 PM
jirasvet's Avatar
jirasvet
Try e-mail Gene at GM parts direct
Old Oct 31, 2007 | 09:33 PM
04tripleblkcoupe
********UPDATE************
Today I found out that on a 2004 C5 you must have all 4 02 sensors connected, On earlier models you only have to move the rear 02 sensors to the front connections, So I hope this will help anyone else who does the Longtube with metric cats.
Now will have to wait for the extended connectors to get here
Also a note on the driverside 02 sensor it has a male connector going into a female, on the passenger side the 02 sensor has a female going into a male connector, and both rear 02 sensors both have females going into males. Anyone with another 2004 have this same setup ?
Old Oct 31, 2007 | 10:21 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
I had the same issues with the o2's, the late production 04's have a different plug than earlier C5's from what i was told by my tuner.
It may have been an anticipated change for the C6 05' model year and the vendor supplying them.
Old Nov 1, 2007 | 12:18 PM
jirasvet's Avatar
jirasvet
Let me guess, sounds like you bought LG motor sports LT headers
Only reason I am guessing this is because they had to send me the
different harness that did not come in the box for my 2004
Only true if running cats, I am willing to bet you will still get codes for
the rear O2 sensors and have to have them turned off if not already done.
I just realized you said you had a tune so they may have turned them off.
They told me on an 04 with or with out cats to still
plug the sensors up and I should be good. Well I went without cats and still got rear activity codes.
I believe others with Hi-flow cats on an 04 have had the same problem.
If you have LGM's LT headers this is the harness they will send.
Got mine the next day when I called them.
Old Nov 1, 2007 | 10:49 PM
04tripleblkcoupe
Well you hit the nail on the head, I hooked all four sensors up this evening, Was trying to do so and get home before 10PM, well I left 1 sensor wire undone and when I started the car up multi misfire code, Put it back on the rack looked everything over and yep there it was.
Plugged it in let it idle for a little bit all seemed fine. locked the shop up and drove it home. ( Of course after the multi misfire I had to hit the throttle a couple of times to clear it all about 8 miles to the house).
Upon arriving at the house I checked for any DTC and none showed up will keep my fingers crossed, but atleast I know now that someone else other than me has gone through this too!
Old Nov 13, 2007 | 04:24 PM
Dougzilla's Avatar
Dougzilla
I have the same problem with the P0135 code just came on today. All the connectors are connected and I still have this code. Could it be a bad 02 sensor ? By the way the cats have been on for three weeks now and this code show up today.
Old Nov 13, 2007 | 06:35 PM
jirasvet's Avatar
jirasvet
If your connectors and wires are good, it could be a bad sensor 1 bank 1.
That code and the cats are not related.
read this
http://www.gearchatter.com/viewtopic10362.php
To Okay Need some Help Code PO135
