Porting LS1 heads Cost effective?
Old Oct 27, 2007 | 11:26 AM
Tom Porter's Avatar
Tom Porter
Default Porting LS1 heads Cost effective?
Is it worth it to have my LS1 heads ported. I am looking to make around450hp on motor. What is the cost of sending my heads off to be ported and valves upgraded to 2.05 intakes and 1.60 exhausts? Can I get there with ported LS1 heads? The cam I intend to use will be around 230 duration and in the 580 lift range.
Old Oct 27, 2007 | 02:55 PM
TYSON1997's Avatar
TYSON1997
I would just buy a set of low mileage 243 heads for cheap and send them off for porting or buy from some vendors who sell ported ls6 heads. Rebuilding your heads if a waste of money when there are so many new sets of heads out there for so cheap. I got a set of 241's w/ 7 miles and 1 dyno pull on them for about $200. Way cheaper than rebuilding my old set completely. Also I would let you heads choose the camshaft, not just randomly pick a camshaft. Bang for the buck I know several people who are more than satisfied w/ patriot heads. You might be 10 hp shy of afr's on a 346 but your at half the price.
Old Oct 27, 2007 | 03:14 PM
AU N EGL's Avatar
AU N EGL
450 on ported LS1 heads? No I tried
even the best LS1 ported head will not flow as well as stock LS6 heads. The PP LS6 heads, a great cam,( LGX3 or similar) under drive pully and tune will get you close to 450 hp
Old Oct 27, 2007 | 03:32 PM
BATM4N's Avatar
BATM4N
I verified with a local tuner and he said the same thing.
Old Oct 27, 2007 | 04:50 PM
TLewis4095's Avatar
TLewis4095
A good set of CNC'd heads can be had from several supporting vendors here for reasonable cost. Try Scoggins Dicky as just one example.
Old Oct 27, 2007 | 05:08 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Just buy a set of aftermarket ported stockers, less downtime and better results.
Old Oct 27, 2007 | 09:18 PM
Corvette Don's Avatar
Corvette Don
Get yourself some LS6 heads for ~$500 and hand port them yourself like I did or send them off to be ported, LS1 heads will not get you 450 rwhp, CNC LS6 heads with bigger valves and a nice cam with ALL the bolt ons and a good tune will get you 450 on a dynojet.
Old Oct 27, 2007 | 10:03 PM
Nespeed's Avatar
Nespeed
What about LS2 heads?
Old Oct 27, 2007 | 10:05 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
LS2 heads = LS6 heads.
Old Oct 28, 2007 | 02:53 AM
Corvette Don
Thats what I got 2005 heads off a LS2 but they are still 243 castings
Old Oct 28, 2007 | 03:09 AM
MJD's Avatar
MJD
I'm going to put the so called facts in this thread to the test. Check the thread I started a couple of days ago. I'm having a set of stock 241's ported and will be picking them up today. I will be posting flow data on these. I did these heads on exchange so the only thing I paid for is port work, they have stock valves as well. The price tag was just over 700.
http://forums.corvetteforum.com/show....php?t=1846963
Old Oct 28, 2007 | 07:49 AM
AU N EGL's Avatar
AU N EGL
I bought some slightly used Ported 243s for $800 back in July of 03
Old Oct 28, 2007 | 09:11 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
thinking of going the same route with the LS6 heads...will be interesting to see the LS1 flow data as well...great info so far..
Old Oct 29, 2007 | 03:37 PM
gsxrjack's Avatar
gsxrjack
sorry for slight hijack, but can LS2 heads just bolt right on to a LS1 motor...mine is a 2000 C5...just a simple yes it can with a new gasket or no you have to buy new rockers etc etc
thanks
jack
To Porting LS1 heads Cost effective?
