Cooling question
If so, it kinda sounds like it's actual open/close points are a little higher temp than the nominal rating. It's not a serious problem as you describe it, but it's not normal either.
Low coolant level could also create temp swings like that at cruise, but your description sounds more like the Tstat.
Check the coolant overflow tank. The coolant level (obviously) needs to be above the COLD (Minimum) level with a cold engine (one that has sat overnight). If the level is low (which I suspect it is) fill with a 50/50 mix of coolant and distilled water. The coolant should be Dexron, an orange colored coolant. If the coolant is green ... whoever did the work put the wrong coolant in the engine.
sounds like air in the systemI did the drain and fill procedure by the book and still had air in the system....I ended up loosening the pump and retightening everything and topped it off again to make it right...never ever had that happen before
I have done a drain and fill numerous times never an issue until this last time.
Around town does it get to higher temperatures? If not, your cap may be bad.
Here is the normal operation, fan set points are higher than most people think:
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Here is proceedure for filling the radiator to ensure air is out. You multifill and rev engine to 3,000 rpm:
Document ID# 99062
1997 Chevrolet/Geo Corvette
Draining and Filling Cooling System
Caution
With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
NOTICE
When adding coolant, it is important that you use GM Goodwrench DEX-COOL® or HAVOLINE® DEX-COOL® coolant. If Coolant other than DEX-COOL® or HAVOLINE® DEX-COOL® is added to the system the engine coolant will require change sooner; at 50 000 km (30,000 mi) or 24 months.
Notice
DO NOT use cooling system seal tabs, or similar compounds, unless otherwise instructed. The use of cooling system seal tabs, or similar compounds, may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
Drain and Fill Procedure
Important
If the procedure below is not followed a low or high coolant level condition and/or vehicle damage could result.
Park the vehicle on a level surface.
Follow the steps below to remove the radiator surge tank fill cap:
Slowly rotate the cap counterclockwise1/4 turn and then stop. Do not press down..
Allow any residual pressure, indicated by a hissing sound, to be relieved.
After all hissing stops, continue turning counterclockwise to remove the cap.
To tighten the cap, use hand tight pressure only.
Open the radiator drain ****.
Allow the system to drain completely.
Inspect the engine coolant:
Discolored -- follow the flush procedure below.
Normal in appearance -- Continue with the next step.
Close the radiator drain ****.
Important
When filling the cooling system use a 50 to 60 percent concentration with DEX-COOL® coolant.
Fill the system through the surge tank opening.
Fill half the capacity of the system with 100 percent DEX-COOL® coolant.
Slowly add clean drinkable water to the system until the level reaches to the base of the neck.
Start the engine.
Idle engine for 1 minute.
Install surge tank cap.
Cycle the RPM, idle to 3000 in 30 second intervals until engine coolant reaches 99°C (210°F).
Shut off the engine.
Refer to step 3 above to remove the surge tank cap.
Start the engine.
Idle engine for 1 minute and fill surge tank to 1/2 inch above COLD FULL mark on the radiator surge tank.
Install the surge tank cap.
Top off coolant as necessary, 1/2 inch above FULL COLD mark on the radiator surge tank.
Rinse away any excess coolant from the engine and the compartment.
Inspect the concentration of the coolant.
Flush Procedure
Important
Do not use a chemical flush.
Block the drive wheels.
Place the transmission in Park or Neutral.
Engage the parking brake.
Run the engine until the thermostat opens.
Stop the engine.
Follow the drain and fill procedure using only clean drinkable water repeat if necessary until the fluid is nearly colorless. Refer to the drain and fill procedure.
Fill the cooling system. Refer to the drain and fill procedure.
You may want to verify that they did not reuse the old thermostat.
1) Coolant temp sensor is flakey ... it is giving you invalid readings ...
2) Serpentine belt is slipping ... the water pump is not consistently moving water through the system
3) The new thermostat is flakey
4) The new water pump is flakey
I'd look at the belt first ... if it is showing any signs of cracking or glazing, I'd replace it. Relatively inexpensive, and about a 3 to 5 minute job to do.
Second thing I'd consider is the temp sensor ... since you replaced the pump and thermo ... it seems like the next likely suspect. You can replace it pretty easily, but if you have some way to measure the temperature of the head (one of those IR temp guns) see if the head temp is fluctuating as the gauge claims. Otherwise consider a new temp sensor.
Otherwise it comes down to the water pump or thermo being bad ... the coolant system is pretty simple, these would pretty much have to be the remaining causes.
Good luck, keep us posted .....
I stand by my original reply...it sounds like the new one is a little off it's nominal rating. Air in the system won't swing the temp in such a controlled fashion, and a bad temp sensor certainly won't either.
