99 fuel filter replacement
Old Oct 28, 2007 | 06:44 AM
vetter79's Avatar
vetter79
Default 99 fuel filter replacement
Have a 99 C5. Has anyone replaced their fuel filter and if so what have you found to be the easiest way? Any step by step instructions would be really appreciated. Auto has 70+ K miles and have done all else but this.
Thanks in advance for any info guys!
Old Oct 28, 2007 | 06:47 AM
lucky131969's Avatar
lucky131969
The service manual gives step by step instuctions. I'd be lost without it.
Old Oct 28, 2007 | 08:44 AM
Oldvetter's Avatar
Oldvetter
Here you go:
Document ID# 307691
1999 Chevrolet/Geo Corvette
In-Line Fuel Filter Replacement
Removal Procedure
Tool Required
J 34730-1A Fuel Pressure Gauge
Important
There is no service interval for the fuel filter replacement. Only replace a restricted fuel filter.
Clean the fuel tanks if you find a restricted fuel filter.
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Disconnect the negative battery cable.
Relieve the fuel system pressure. Refer to the Fuel Pressure Relief Procedure .
Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Lower the left muffler (auto trans equipped vehicles only). Refer to Muffler Replacement in Engine Exhaust.
Clean all the fuel filter/pressure regulator connections and the surrounding areas before disconnecting the fuel pipes in order to avoid possible contamination of the fuel system.
Disconnect the fuel feed pipe quick-connect fitting (1) from the fuel filter/pressure regulator (2). Refer to Quick Connect Fitting(s) Service (Plastic Collar) .
Disconnect the fuel return pipe quick-connect fitting (4) from the fuel filter/pressure regulator (2). Refer to Quick Connect Fitting(s) Service (Plastic Collar) .
Remove the fuel filter/pressure regulator bracket mount nut (2).
Disconnect the fuel system ground strap from the fuel filter/pressure regulator mounting stud.
Disconnect the fuel feed pipe (3) from the outlet side of the fuel filter/pressure regulator (2).
Remove the fuel filter/pressure regulator and bracket (1) from the stud (3).
Cap the fuel pipes in order to prevent possible fuel system contamination.
Remove the fuel filter/pressure regulator from the bracket.
Installation Procedure
Remove the protective caps from the new fuel filter/pressure regulator.
Install the new plastic quick connector retainers on the fuel filter/pressure regulator inlet and outlet tubes. Install the new retainers in the same positions as on the old fuel filter/pressure regulator.
Install the fuel filter/pressure regulator into the bracket.
Remove the caps from the fuel pipes.
Connect the fuel feed pipe (3) to the outlet side of the fuel filter/pressure regulator (2).
Install the fuel filter/pressure regulator and the bracket (1) to the mounting stud (3).
Engage the anti-rotation tab (3) of the fuel filter/pressure regulator bracket (2) into the hole of the tunnel reinforcement (1).
Connect the fuel system ground strap to the fuel filter/pressure regulator mounting stud.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the fuel filter/pressure regulator bracket nut (2). Tighten
Tighten the fuel filter/pressure regulator bracket nut to 4.5 N·m (40 lb in).
Connect the fuel return quick-connect fitting (4) to the fuel filter/pressure regulator (2). Refer to Quick Connect Fitting(s) Service (Plastic Collar) .
Connect the fuel feed quick-connect fitting (1) to the fuel filter/pressure regulator (2). Refer to Quick Connect Fitting(s) Service (Plastic Collar) .
Raise the left muffler (auto trans equipped vehicles only). Refer to Muffler Replacement in Engine Exhaust.
Lower the vehicle.
Tighten the fuel filler cap.
Connect the negative battery cable.
Inspect for leaks.
Turn the ignition switch ON for 2 seconds.
Turn the ignition switch OFF for 10 seconds.
Turn the ignition switch ON.
Check for fuel leaks.
Program the transmitters. Refer to Transmitter Programming/Synchronization in Keyless Entry.
Perform the idle learn procedure. Refer to PCM Idle Learn Procedure .
Old Oct 28, 2007 | 10:47 AM
vetter79's Avatar
vetter79
Thanks Oldvetter for the info - seeing that it's not plugged at the moment, I'll leave it alone for the time being.
Will save this thread for future ref. for the future though!!
Old Oct 28, 2007 | 12:08 PM
lp2k's Avatar
lp2k
Question:
If i put the injector cleaner in the cars tank, and run my regular premium, can that cleaner stuff clean the lines and the filter? maybe burn the gunk off ?
(seeing we dont have to replace the filter , only on a need to do basis)
curious, please dont flame
Old Oct 28, 2007 | 01:12 PM
RED99's Avatar
RED99
Injector cleaner will not clean a dirty fuel filter.
Old Oct 31, 2007 | 10:36 PM
HollywoodFRC's Avatar
HollywoodFRC
Default It's easy but messy
Changed mine on my '99. Wrap filter with rag will minimize spilled gas. You'll still get gas on you. Be careful. Follow the procedures. It's not that hard.
Old Oct 31, 2007 | 11:30 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I did mine a while back, 2nd time for it... easy job after you jack the rear wheels up off the ground and of course having blocked the front wheel(s). You need the quick disconnect plastic tool for the lines. Have rags handy and don't work on it with hot pipes..hint, hint.
To 99 fuel filter replacement
