I am looking at the possibility of swapping out the Torque Converter on my stock 2001 LS1 Coupe.
I have read Patches posts on the Yank SS3200 so far. My questions are...
(1) What is the stall speed in the GM stock converter I have now?
(2) What would be a reasonable price to pay a transmission shop to make this swap?
(3) The transmission shop I am considering was recommending Pro Torque brand. How does this compare to Yank and do they have something comparable to the SS3200?
(4) Do I need to make any other modifications to see the benefits of a new converter?
I never take the car on the track - it is for sprited street driving only. Reliability and smoothness is paramount.
The ? to # 1 is 2600 ,The ? to # 2 is 550 for a tranny & converter swap By the dealer who did mine, #3 I havent heard of the Pro Tq ,I have a Yank 3600 & Its nice,3200 Been there done that ,Could not tell i had a Converter in the car, I would Put the gear in the car ,when u do the converter & A transgo shiftkit as well jmo
I was told the same thing--1400-1600 is stock--driveability issues can arise with stall over 2800 so be prepared for it to drive alot different then stock--ALSO a tranny cooler is a must with any stall converter--AND a tune is neccessary to elimiante false codes and limp modes --misfire tables must be adjusted--PWM table--TQ mngmt tables
I've heard good things about Pro Torque--What I learned was to keep away from the smaller diameter converters if you are mostly going to street drive the car--When going to smaller diam converters--the TCC clutch is so small that it creates problems in the long run--such as overheating--popping in & out of lock-up--i went with a standard size 12" re-manufactured converter and love the way it works--on the street you can hardly tell its in there--but when you romp on it ---it comes alives--and no overheating and the TCC clutch works flawlessly--(phoenix transmissions converter--2600 stall) $319--
I even have a YANK 3200 and now it's better for my application but for your application I'd go with a YANK 2800 Stall http://www.converter.cc/converters/street/GM/2/main.htm and you'd be real happy with it! I would not go any larger!
Swap price should be about $300.00 just find and ask around for a good reputable shop in your area!
Thanks,Matt
1600 wow ,I have been Wrong Before ,I apoligize for the Wrong answer to your ? I for some reason or another was thinking it was a 2600 stall
Thanks,Matt
I installed a Yank 2800 in my 03, A4 when I put in 3:42 gears a month ago. No slip and a nice kick. I did not install a trans cooler. I haven't seen the trans temp go over 200 degrees.
Thanks,Matt
So, when you refer to "Swap Price" does this refer only to the LABOR charges? I take it the stock converter has no real resale value?
So, sounds like I am looking at about $600 - $900 to swap this out.
Additional questions:
(1) Would this be that noticible with a stock engine?
(2) Does it put any additional strain on a particular system?
(3) Does it affect GMPP Extended warranty?
(4) Do I really NEED a transmission cooler with a 2,800 or lower stall? If so, what does that add to the cost?
(5) Do I need to have anything re-programmed following this change? If so, do transmission shops do this?
The swap out price is what it is for the tranny shop to do the labor around $300-$400 including fluids anymore than this then I'd be real skeptical of taking it there!
You will keep your stock converter and take it home and store it! WHY?
Well because no matter what you do you always keep your stock things just incase you want or need to sell your Vette you'll have the stock pieces to offer as well which will up the resale value of the Vette!
No you don't always need a external cooler for the new stall converter-even with mine I don't need one because when you go for drives it is in lock-up!
However if you are going to race, race, race all the time and be hammering it everywhere you go you might think of an extra cooler!
(5) Do I need to have anything re-programmed following this change? If so, do transmission shops do this?You might consider changing you shift pressures and shift points from stock with a handheld tuner or having your tuner change it for you! (I'd do the handheld if you have one!)
