Lazy eye (headlight) on 2004 C5.
Old Nov 2, 2007 | 12:50 PM
Blue Thunder's Avatar
Blue Thunder
Cruise-In I Veteran
National Champs Gators 4 St. Jude '09
Default Lazy eye (headlight) on 2004 C5.
I have suddenly had the issue of turning the lights off and one of them staying up, although the bulb is not illuminated. Then when you turn them back on, that one goes down and the other one comes up and on correctly. So it is constantly having one light up while the other is down.
Anyone had this problem? Any possible solutions.
Car is 2004 C5.
Thanks.
Old Nov 2, 2007 | 02:45 PM
gsadowski's Avatar
gsadowski
You probably have a stripped headlight gear.
check this link for some info on it.
http://forums.corvetteforum.com/show...headlight+gear
Old Nov 2, 2007 | 02:46 PM
hawaiiC5's Avatar
hawaiiC5
St. Jude Donor '09
Old Nov 2, 2007 | 03:06 PM
Blue Thunder
Cruise-In I Veteran
I actually just replaced the gear about two weekends ago with the brass version from B. Franker....any other possibilities? It will crank up and down....so I don't believe the gear is damaged. It is brand new.
Old Nov 2, 2007 | 06:00 PM
jdmvette's Avatar
jdmvette
Night Owl for life
take a look at my posts here:
http://forums.corvetteforum.com/show...ghlight=washer
these fixes i have listed will solve your problem.
To Lazy eye (headlight) on 2004 C5.
