Fuel Trim error code
Old Nov 4, 2007 | 08:42 AM
jml_911's Avatar
jml_911
Default Fuel Trim error code
Hi guys
I got an error code come up last night
Checked it on the Diablo tuner i have (thats proved handy)
Its a P0171 Fuel trim Bank 1 - system too lean
It was just after i put a full tank of petrol in - usual high grade
I suspect the fuel is duff perhaps
Ive reset the code and now its seems ok - I have also set the tune back to a factory preset, rather than then performance tune, until i can top up the fuel from my usual gas station
Does this sound like the right thing to do ?
Bare in mind that Im in the UK - so cant pop down to my local Corvette dealer !
thanks
Old Nov 4, 2007 | 11:52 AM
jirasvet's Avatar
jirasvet
Sounds like the right thing to do putting it back to factory, but may not
be the problem. Just for one bank to be lean would lead me to believe
that there are other issues at hand. Possibly a vacuum leak ,or O2 sensor
problem.
Old Nov 4, 2007 | 11:57 AM
jml_911's Avatar
jml_911
cheers
just took it for 5 miles - it hasn't thrown the code again since I've reset it
I'll get some new fuel in it and see how it goes
Incidently i can feel a real difference in the performance going back to the factory preset - i didn't notice much different when i first installed the Predator preset.
Old Nov 4, 2007 | 12:05 PM
jirasvet's Avatar
jirasvet
Intresting
Old Nov 4, 2007 | 12:07 PM
jml_911's Avatar
jml_911
Originally Posted by jirasvet
Intresting
I mean lower performance levels
Old Nov 4, 2007 | 06:11 PM
jirasvet's Avatar
jirasvet
Default understand
Old Nov 4, 2007 | 07:56 PM
vettenuts's Avatar
vettenuts
Check the fuel cap too if this just turned up since the re-fill. No other work on the car other than new fuel?
Old Nov 4, 2007 | 08:11 PM
jml_911's Avatar
jml_911
Correct - been running the same spec for 6 months
Just a refill - been out tonight in it and did about 40 miles - with no warning lights - so figure it was a glitch that's gone away (i hope)
To Fuel Trim error code
