H/C in CA.... ?
Old Nov 5, 2007 | 06:14 PM
socal guy's Avatar
socal guy
Default H/C in CA.... ?
hey guys... i am getting ready to pull the trigger on a smogable H/C set-up for my 2002 Z06.
i passed smog with my old SS
(ported LS1 castings, 222/224 .566/.568 114, LS6 intake)
and was wondering what specs you are running and if they passed the sniffer yet?
i am trying to figure out what is my MAX cam size and which HEADS have the best VALUE.
thanks!
dyno graphs welcome!
Old Nov 5, 2007 | 06:32 PM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
Orange County Corvette ONLY!!
949.830.VETT
Old Nov 5, 2007 | 10:52 PM
spiral04's Avatar
spiral04
The best heads are Trickflows, AFR's, ETP, and TEA. These aren't cheap though. Patriot's, Texas Speed, and Livernois are good lower budget heads. The largest cam to pass smog in CA IS A 224/228 114.
Old Nov 5, 2007 | 11:05 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
(mine is .221/.221 .560/.560 @114--passed easily could have gone a little bigger--however have never seen a 112 LSA pass -be careful with the LSA--114 or more
Old Nov 6, 2007 | 01:37 AM
Ron@RPM's Avatar
0Ron@RPM
Former Vendor
I think that Al @ LAPD passed with a cam that is larger than mine which has a 230/236 duration at 050. It was tuned before hand and passed with flying colors.
Give him a call for details.
Old Nov 6, 2007 | 01:44 AM
spiral04's Avatar
spiral04
Give him a call for details.(818) 998-DYNO
Hi Keith. You're right, you can pass with a larger cam but the cars tune needs to be messed with before the smog check so it will pass. Adjusting the timing or Air-fuel ratio or something like that??
Old Nov 6, 2007 | 10:48 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I got 224/228 581 and 588 lift on 114 with TFS 215 heads!
Passes along with the ProCharger!
Thanks,Matt
Old Nov 6, 2007 | 01:28 PM
TM-Z06's Avatar
TM-Z06
That's not true. The above is one of the easiest to pass, but I've seen 228/228 114lsa and 228/232 115lsa cams pass.
Old Nov 6, 2007 | 02:01 PM
socal guy's Avatar
socal guy
now that sounds liike a decent CA set-up....
Old Nov 6, 2007 | 03:27 PM
spiral04's Avatar
spiral04
Did it pass without messing with the tuning? I have a 228/230 112 and will pass but it will have to have the tune played with so it will pass.
Old Nov 6, 2007 | 04:22 PM
GKE's Avatar
GKE
I have a 224/226 114, TEA heads, Fast 90/90, u/d and all the normal stuff. The only part that fails in the visual on the LG lt headers. It will pass on the sniffer.
Old Nov 6, 2007 | 06:44 PM
socal guy's Avatar
socal guy
that sounds good to me...
what kind of rwhp numbers did you make? 415ish? 380tq?
can you post or link your dyno graph?
Old Nov 6, 2007 | 07:11 PM
TM-Z06's Avatar
TM-Z06
They had to be tuned to some degree to pass. However, I've seen a 224/224 114lsa fail CA smog. The owner took the car to his tuner, they changed a few parameters, and it passed with flying colors.
Old Nov 6, 2007 | 07:53 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Give us a call, but better still, please stop by and see what we do and how we do it. We can produce a reliable 450 RWHP package that does all the right stuff including make great torque and pass the sniffer.
Old Nov 6, 2007 | 09:01 PM
socal guy's Avatar
socal guy
457rwhp and 429rwtq
and pass CA smog.?
sounds a little to good to be true.
sounds like a BAD *** ride too....
can you give a quick parts run down.
and approx. cost?
Old Nov 6, 2007 | 11:34 PM
0C_Williams@RPM
Former Vendor
457rwhp and 429rwtq
and pass CA smog.?
and approx. cost?
All true
- I'll PM the entire package(s) in the morning...
thanks,
Old Nov 7, 2007 | 12:20 AM
GKE's Avatar
GKE
Kinda funny but those are exactly the numbers Charlie was able to pull out of it. I just got back from his shop on Sat, thanks Charlie.
Old Nov 7, 2007 | 09:06 PM
socal guy's Avatar
socal guy
ding ding, we have a winner!
i am pretty good at guessing dyno numbers.
ill be waiting for that PM.... RPM.
To H/C in CA.... ?
