More power but!!!
Old Nov 7, 2007 | 06:39 PM
dwestsr's Avatar
dwestsr
Default More power but!!!
I have an 04 mn6 coupe that is bone stock/ with 19k miles. I have been reading about H/C changes headers/ exhaust etc. here on the forum for a long time. I too would like more power but one of the things I like about my vette is it's low rpm smoothness while pulling 6th gear on the interstate @ 70/75 MPH. I don't want to give this up. What has been your experience with aftermarket cams in regards to low end grunt? I know that H/C is the heart and soul of increased power but what price glory? While I would love more power, mine is not ever going to see a drag strip or track. In writing this , I have just about talked myself out of any mods. What do you think?
Old Nov 7, 2007 | 08:20 PM
cam99's Avatar
cam99
You can have both....
The same smoothness and more power. It's all in the cam selection.
Pulling in 6th? I had to get 4.10's to get pulling in 6th!
You want inexpensive sotp performance change your rear gears!
Old Nov 7, 2007 | 09:39 PM
B-Vette's Avatar
B-Vette
Lingenfelter C5 480HP modification.
Old Nov 7, 2007 | 11:29 PM
GeorgeB's Avatar
GeorgeB
See my sig for mild combo and 100 extra hp. Absolutely zero driveability issues. As far as "pulling" in 6th, I can't stand to wait so I pick another gear. If you mean lack of bucking or other engine complaints then I have none of those either. At idle you can just tell that you are driving something other than a minivan and I think that is a good thing!
Old Nov 7, 2007 | 11:34 PM
mk2001c's Avatar
mk2001c
You can make up most of the low end loss of a bigger cam by bumping your compression ratio as long as you don't go crazy with the overlap (stick with a 114 LSA).
Old Nov 8, 2007 | 05:46 AM
RoganR's Avatar
RoganR
whats your RPM @ when you are in 6 with 4:10s?
Old Nov 8, 2007 | 11:53 AM
CanadianVetster's Avatar
CanadianVetster
What about starting small....... i.e. intake and cat back... maybe hand tuner
should boost you 20 - 25 hp... no engine mods... then decide on headers and/or cam work if you catch the fever.../
To More power but!!!
