Very Squeaky belts
Old Nov 8, 2007 | 09:23 AM
LW97Vette's Avatar
LW97Vette
Default Very Squeaky belts
Would anyone know what I can do with belts that are very noisy until the car warms up? Usually 5 minutes and you don't hear them. But those first 5 minutes make the car sound like a jaloppy.
Thanks,
John
Old Nov 8, 2007 | 11:15 AM
ALVETTE00's Avatar
ALVETTE00
Try using some Belt Dressing...can get it at any automotive store.
Old Nov 8, 2007 | 11:43 AM
craig-o's Avatar
craig-o
Replace them. Usually they squeal because they're glazed, and the squeal is the sound of them slipping on the pulley.
Modern belts only take ~5 minutes to replace. Put a wrench on the tensioner pulley, rotate it to free the belt, remove the old one. Thread the new one, rotate the tensioner pulley again, loop the belt over the tensioner and you're done. Don't forget to replace the A/C belt too. Basically the same procedure.
Old Nov 8, 2007 | 01:47 PM
jedblanks's Avatar
jedblanks
From experience, there is one and only ONE answer to this problem -- New Goodyear gatorback belts on all accessories.
I got mine from Autozone. Belt dressing made my problem worse and I had to end up cleaning the goop off the pulleys
Old Nov 8, 2007 | 02:52 PM
GREG O.'s Avatar
GREG O.
Cheap auto tranny fluid does the job. sent PM
Old Nov 8, 2007 | 02:58 PM
TEXHAWK0's Avatar
TEXHAWK0
Also, the GM service manual warns NOT to use belt dressing on serpentine belts since it can cause the belt to deteriorate.
You can mist water on the belt to confirm it is the source of the noise, but if it is, just replace the belt.
Old Nov 8, 2007 | 05:37 PM
Jeff_in_Atl's Avatar
Jeff_in_Atl
I third that. I have seen Goodyear Gatorback belts stop a squeek for good many times. Don't get anything other than a Gatorback or you will be doing it again down the road.
Old Nov 8, 2007 | 06:37 PM
03newjersey's Avatar
03newjersey
Default It may not be your belts...
Check out this post...
http://forums.corvetteforum.com/show....php?t=1836905
Its difficult to determine where the squeak is coming from mine turned out to be one of the AC pulleys. Goodluck.
Old Nov 8, 2007 | 06:43 PM
vettekidc5's Avatar
vettekidc5
here is a old school tip I picked up from a guy, and Ive been a mechanic for about 6 years.. I thought I heard it all when it came to belts and belt dressimg etc..
TRY THIS. I personally did this on both of my belts om my vette.. It was squeeking JUST as you said in the mornings..
Put black RTV on the groove of the belt... Just take your finger and put a nice bead on it, enough to stretch across the width of the belt in one spot and apply it on both belts. Let it run while its wet.. It will spread across the belt and It will quiet the noise.
I tried this and Im amazed. No more squeaks in the morning..
Old Nov 8, 2007 | 08:17 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Just this morning I replaced the accessory serpentine belt for noise issues that just started. Noise gone. It was coming off the belt on the power steering pump pulley. Belt looked good but apparently worn.
Old Nov 8, 2007 | 08:26 PM
neokorros's Avatar
neokorros
so if i go to autozone to buy some gatorbacks i need two different belts? serpentine and a/c belts?
~ nick
Old Nov 8, 2007 | 09:53 PM
dgrant3830's Avatar
dgrant3830
The Gatorback is what I got from Kragen this morning. I didn't replace the compressor belt but its probably a good idea.
Old Nov 8, 2007 | 10:11 PM
mellowyellow01vert's Avatar
mellowyellow01vert
I spray my belts with Silicone spray whenever I am under the hood. I have over 140K on the original belt and it still looks good.
Old Nov 9, 2007 | 03:09 AM
dieseldave56's Avatar
dieseldave56
Default belt dress rehearsal............
Never apply any belt dressing or petroleum based fluid. Be sure it is the belt and not the idler. Belts squeal because they are slipping or the pully surface are glazed. Appy , sparingly, either tooth paste ( not the whitening type, Floride is OK , LOL). Or apply bar hand soap to the belt while idling. This simply adds the grip and will not effect the belt other than making it smell like spring time .....I like it too!!
Old Nov 9, 2007 | 03:40 AM
lucky131969's Avatar
lucky131969
I don't care what knuckleheads tell you, squeaking belts is a sign of wear. DO NOT spray lubricants or belt dressing on a serpentine belt . Replace belts and pulleys as required. Spraying lubricants and belt dressing on belts is strickly a old school/hillbilly fix.
Old Nov 20, 2007 | 09:28 AM
jmorr649's Avatar
jmorr649
Default Belts squeeking and ac makes a funny noise
So I have a belt that is squealing/squeeking too. It happens primarily when I take it out of gear. When I get moving it is fine with no problems at all. I had it checked out last time I had the oil changed. They said they could not replicate it, which is complete BS cause it does it anytime it is started and sitting still.
The other weird thing is that when this started my AC now makes a noise like a bird worrrrdling or something. It is subtle, but there. I figure the two are related.
My C5 is a 1998 with the original belts. The guy that changed the oil for me said the belts look great. The car only has about 32K original miles on it.
I have been a bit afraid of trying the "soap" trick that I have read about and my mother-in-law swears by. I figure there is a better answer than a 1.50 bar of Irish Spring.
Help! Thanks!
Old Nov 20, 2007 | 10:38 AM
uracowman's Avatar
uracowman
When mine was squeaking, it progressively got worse as the engine warmed up and never went away.It turned out the be the AC tensioner pulley.
Hope this helps.
Old Nov 20, 2007 | 11:04 AM
jmorr649's Avatar
jmorr649
Default Good thought
Mine does not go away when it warms up, but when I am moving it is gone. Not sure what to make of it. Pretty much as long as its in gear its fine...the AC thing wordles all the time though.
Old Jul 6, 2008 | 11:26 AM
B-Vette's Avatar
B-Vette
I'm having a belt problem now myself (serpentine) and I've replaced the tensioner and gone through 3 different manufacturers belts. A new belt will stop the problem for awhile but it aways comes back, usually after a long trip.
Once the squeak manifests itself again I have a constant squeak on cold start up and it continues after the engine is warmed up. Squeak does not go away and belt eventually gets "glazed" on it's backside. Belt sides and grooves are in near perfect condition (except for the glazing on the backside as mentioned). I'm going to try changing the Idler pulley next.
To Very Squeaky belts
