Cam install....cost?
Old Jun 17, 2008 | 11:52 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We charge $2,995 for our complete cam kit.. Dont forget we use the Comp 921 springs which are usually double the price of some of the others..
Here is a link to the site..
http://www.eastcoastsupercharging.com/CustomCam.html
Old Jun 17, 2008 | 01:25 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
People need to realize the you just dont SLAP in a new cam and spend a couple hours on the dyno..
A STANDARD cam swap consists of:
  • Cam
  • Spring Set
  • Pushrods
  • waterpump gaskets
  • Front cover seal
  • Crank seal
  • Crank pulley
  • Coollant
  • Oil
  • Filter
  • A whole lot of labor
  • Dyno tune
While your there, you'd be CRAZY not to replace the timing set and oil pump. Those 2 things alone can add a couple hundred bucks to the price (One the cheap side)
What I do is upgrade anything i take of with free labor.
If I do a clutch, I'll actually install your headers for FREE.
Originally Posted by TLewis4095
;1562673516
I highly recommend a ported Hi Vol oil pump while it is apart.
Our $1895 special includes custom grind cam up to .600 lift & all fluids/gaskets/hi vol oil pump. That is not just the install, but includes the cam & a full dyno tune.
Old Jun 17, 2008 | 03:48 PM
jpandes's Avatar
jpandes
What a deal!
