Cam install....cost?
Old Nov 8, 2007 | 09:28 AM
blackblack94's Avatar
blackblack94
Default Cam install....cost?
What is typical cost to have a cam only installed? I have got quoted anywhere from $2,100 to $3,000. Let me know!
Edit: These prices include, custom camshaft, dual PRC springs, Ti retainers, steel seats, new locks, valve seals, moly pushrods and installation and dyno tune.
Old Nov 8, 2007 | 11:10 AM
fsuforever's Avatar
fsuforever
That price is totally insane ,If i coudnt do it myself,& bTW,its not too hard to do,Just time consuming , & I was gonna pay a Reputable shop to do the cam install,600.00 To 1,000 is more realistic,I was quoted 1,000 for a cam change lastyear ,From The Dealer
Old Nov 8, 2007 | 11:22 AM
blkdevl's Avatar
blkdevl
Old Nov 8, 2007 | 11:26 AM
blackblack94
Sorry I should have been more specific. These prices include, custom camshaft, dual PRC springs, Ti retainers, steel seats, new locks, valve seals, moly pushrods and installation and dyno tune.
Old Nov 8, 2007 | 11:33 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I paid $1800 , cam , springs , rods, and tune ....
Old Nov 8, 2007 | 12:40 PM
chris308's Avatar
chris308
18-1900 is the going rate around here for parts, install, and dyno tune
Old Nov 8, 2007 | 12:46 PM
American Hydrocarbon
Guest
Posts: n/a
And even a new oil pump for less then 2K in Tampa.
Old Nov 8, 2007 | 01:40 PM
nickolbag's Avatar
nickolbag
Seems about right to me.
Old Nov 8, 2007 | 10:56 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
I need to learn how to do cam installs and charge $3000.
I guess overhead is a b!tch
Old Nov 9, 2007 | 08:21 AM
blackblack94
Do you need a new oil pump when doing a cam install? As you can see I wasn't quoted for a new oil pump.....
Old Nov 9, 2007 | 08:27 AM
TLewis4095's Avatar
TLewis4095
I highly recommend a ported Hi Vol oil pump while it is apart.
Our $1895 special includes custom grind cam up to .600 lift & all fluids/gaskets/hi vol oil pump. That is not just the install, but includes the cam & a full dyno tune.
Old Nov 9, 2007 | 10:22 AM
blackblack94
How about UD pulley? Is that necessary as well?
Old Nov 9, 2007 | 10:51 AM
TLewis4095's Avatar
TLewis4095
Not neccesary, but a good idea to do it at the same time to save labor.
Old Nov 9, 2007 | 10:54 AM
blackblack94
Thanks. What about a 160 degree thermostat? Necessary?
Old Nov 9, 2007 | 11:15 AM
vincentjames501's Avatar
vincentjames501
If you want to keep your engine cooler than yes. I would say just save your money especially during the winter if you plan on driving your car. It will take forever to get really hot air and to heat up your car.
Old Nov 9, 2007 | 09:16 PM
CYA-Vett's Avatar
CYA-Vett
It takes less than a day to swap a cam. A fair shop will charge about $85/hr, anyone who charges you more than $700 for the labor is ripping you off. Realistically it can be done in 6 hours. You can do your own math from there...
Old Jun 3, 2008 | 06:14 PM
jpandes's Avatar
jpandes
Edited: I just had my cam installed with all the supporting mods done by Newtech Performance:
Cam Specs:228/232 115LSA) & the necessary supporting mods springs, gaskets etc.
While they were in there, they suggested a high-volume oil pump & upgraded timing chain.
I also asked them to install and underdrive pulley & belt. And, of course the dyno tune by Nick.
429rwhp/392ft.lbs
Total: $2,800+/-
If you are in Norcal, I highly recommend these guys. Great Service, very knowledgeable and reasonable. * The blue line on the dyno sheet was with Vararam & LT's.
To Cam install....cost?
Old Jun 3, 2008 | 06:35 PM
FullOutPwr's Avatar
FullOutPwr
What if the spec'd cam is more than .600? My cam specs are .612 and .605 which would need to be ground.
Old Jun 3, 2008 | 09:29 PM
TLewis4095's Avatar
TLewis4095
Just depends on the springs we would use....on a grind like that we are still at $1895 or so.
Old Jun 17, 2008 | 02:10 AM
hank freid news's Avatar
hank freid news
1st Gear
I am agree with the user fsuforever. SO If I couldn’t do it for myself,& bTW,its not too hard to do,Just time consuming , & I was gonna pay a Reputable shop to do the cam install,600.00 To 1,000 is more realistic,I was quoted 1,000 for a cam change lastyear ,From The Dealer
________________________
prior to joining the impulsive group hank freid gained operational and asset management experience
Last edited by hank freid news; Jun 17, 2008 at 02:12 AM. Reason: for text correction
