Red Puddle Found Under Car
Old Nov 8, 2007 | 09:46 AM
aschiftner's Avatar
aschiftner
Default Red Puddle Found Under Car
I pulled my A4 coupe out of the garage and noticed the puddle. I'm pretty sure its transmission..... Its toward the rear of the car just forward of the axle and more towards the passenger side of the car. Until I can get the car on my jacks, can anybody give me some advise. I mean I'm hoping that this is just the sump pan and not a blown transmission seal or something that I'd have to take in. Car is and was running fine. Car in now parked. Thanks!!! R/ Al
Old Nov 8, 2007 | 11:52 AM
bucwheat's Avatar
bucwheat
Default puddle
Red is definitely trans. fluid.If you are like me I drive mine very little and it sits in the garage sometimes 3 wks. or longer before I drive it . The seals dry up a little and it leaks a few drops,when I drive it and bring the motor temp. up it stops leaking.I have 4 vehicles and it's hard to drive them regularly. I put a sealer additive in my 97 ford powerstroke diesel and it stopped leaking all together.Don't want to go that route in my vette.:o
Old Nov 8, 2007 | 02:43 PM
nmbis2k's Avatar
nmbis2k
ATF is a pretty red/pink color....but so is the coolant. From your location should be ATF.
When we the last time you had is changed?
How about driving down to the oil change place and having them check your 4l60E level? They will probably recommend a fluid change, but that never hurts.
Old Nov 8, 2007 | 02:54 PM
VetteDrmr's Avatar
VetteDrmr
Be careful about having Joe Cool mechanic check your tranny fluid level. The C5s require you to pull the drain plug with the engine running on level ground, if it's full then the level will be slightly below the plug. Craziest system I've ever seen.
HTH, and have a good one,
Mike
Old Nov 8, 2007 | 07:49 PM
aschiftner's Avatar
aschiftner
I bought the car used a year and a half ago with 60,000 on it. It has never been performed. I was planing on doing it myself. Don't understand why I now have a leak. I do drive the car often. I will be jacking the car on Monday (my day off) and taking a closer look. Don't know what to really look for thats all. R/ Al
Old Nov 8, 2007 | 08:18 PM
bobc997615's Avatar
bobc997615
My A4 had a rear seal leak. It only acted up when the temps got to 45 degrees or less. Finally got fed up with it & fixed it myself during the winter. Plently of wrench time to replace a $48 seal. Drop the rear cradle, exhaust & diff.
Old Nov 8, 2007 | 11:18 PM
SuperSpeed's Avatar
SuperSpeed
St. Jude Donor '08-'10
Mike
that is with manuals...he has an A4 so he should just have to let the car get up to temp and check with the dip stick.
and i dont think you need the engine running to check the fluid level in the M6 either but i could be wrong just the way i used to do it in my fbody
Old Nov 9, 2007 | 05:27 AM
lucky131969's Avatar
lucky131969
Alright! A man that knows what he is talking about!
So can you tell me exactly where the automatic transmission dipstick is on a c5 vette?
Old Nov 9, 2007 | 07:04 AM
VetteDrmr's Avatar
VetteDrmr
There is no dipstick. Trust me, I've done both M6s and A4s.
http://www.idavette.net/hib/C5diy/c5diy2.htm is Hib Halverson's writeup on the C5. Check the "Transmissions and Rear Axle" section of this page.
Good luck, and have a good one,
Mike
Old Nov 9, 2007 | 08:15 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I had the same trouble last winter. A friend who works only on Vettes (and not for a dealership) told me that it's pretty normal when the temps dip. When the tranny warms up it seals.
There is also a vent on top. If you can see fluid on the top of the tranny there's a good chance it was overfilled.
Checking it is a bummer, make sure that it is really secure on the lift. I tried to develop a small dipstick, but brazing to the check plug was a total waste of time. If someone could fix up a dipstick where you could just check it from underneath it would be great and the'd get rich.
I'm adding a cooler up front together with a deeper pan. Trying to figure out a sight glass of some type around the cooler to check the level.
Old Nov 11, 2007 | 09:03 AM
aschiftner's Avatar
aschiftner
Mike
Thanks for the excellent link!! I guess I'll see whats up when the car is on jacks.
Thanks everybody. Weather has been cold this week (below 48) so that may be a contributing factor. I'll keep you posted. R/ Al
Old Nov 12, 2007 | 02:21 PM
damilleniumboy's Avatar
damilleniumboy
crapo, I think I have to do dat too. It's starting to get cold here in KS, and the garage floor where the car sits has wet lubricating spots on it.
Old Nov 12, 2007 | 08:05 PM
aschiftner's Avatar
aschiftner
Well, I got under the car today and the leak is coming out of the rear of the transmission sump/pan....which to me is a huge relief as compared to what it could have been. I'm suprised that is what I found. I'm wondering now if this maintenance has been done before..... Seems unusual that a sump leak would start at 60,000miles. Whether done before or not the filter, gasket and fluid will get done asap. Easy fix as far as I'm concearned. Thanks forum!!!! R/ Al
Old Nov 13, 2007 | 11:20 AM
ZeroHer0's Avatar
ZeroHer0
If you have an automatic, usually i would say start there. another possiblity is if someone has put stop leak in your powersteering. stuff like lucas show up as red in the power steering system.
Old Nov 19, 2007 | 11:25 AM
bucwheat's Avatar
bucwheat
Good advice ,as always
Old Nov 19, 2007 | 02:25 PM
runman's Avatar
runman
pan gaskets dont leak on those trans(unless someone put a cheap one on), fluid leaks through a small hole in the center bottom between trans and diff, then works around pan gsk to make it look like a pan gsk leak. brake clean the area off, spray some powder leak detector around that hole and drive/wait/watch (my money is on a output shaft seal)
been there many times, also replace the outshaft seal on the diff side while your there they leak also
labor should be 6.7hrs if you get a qoute
Old Nov 19, 2007 | 02:55 PM
bobc997615's Avatar
bobc997615
As far as what it takes to fix the seal yourself, check out:
http://mikemercury.home.att.net/342.htm
To Red Puddle Found Under Car
Old Nov 19, 2007 | 05:01 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Old Nov 19, 2007 | 10:17 PM
aschiftner's Avatar
aschiftner
Well, being that I thought it was just the pan I thought I'd pay the money for the flush and fluid swap. After taking it to a national shop that I have taken my other vehicles too they called me and said that they did not see a leak and that they were not going to work on it. They recommended the dealership.
So I took it to the dealership. Grey Cheverlot in Port Orchard. Real nice people. Again figuring just a flush and fluid swap. Plus I'd feel allot better after what I was told at the other place. \\ OUTCOME: \
I have a leak in the fluid pan and 2-4 servo cover seal..... $300 to fix which includes the parts, labor and new fluids. Thoughts????
Thanks forum!!! R/ Al
Old Nov 20, 2007 | 09:46 AM
runman's Avatar
runman
my money is still on having to pull the diff
300 bucks is cheap if thats all it is
keep us posted
26 years working on drivetrain for GM, can't remember the last time i fixed a leak due to a servo cover seal though
