Car Calcs, some usefull stuff
Old Nov 8, 2007 | 11:49 AM
mn_vette's Avatar
mn_vette
Default Car Calcs, some usefull stuff
Guys and gals,
Over the years I've been doing tons of math while upgrading my car. Everything from which valve spring to which gear ratio to what throttle body.
I've compiled a bunch of calculations into a spreadsheet that I thought I would offer up. Its nothing overly special, you can find most of the stuff on the web. But its nice to have a copy so you can save the calculations.
Here's what it has:
Engine size Calculation
-input bore/stroke/cylinders and get ci
-also has ci to L and L to ci conversions
Engine CFM and LB/MIN calcuations (great for boosted cars)
-Input engine size/engine VE to get CFM
-Input IAT and get LB/MIN
-N/A cars use 0psi boost
-Calculates up to 25psi boost
-Also has psi to ATM conversion
Tire Diameter Calculation
-Input tire size to get sidewall/radius/diameter/circumference/Tire Width
-Calculations in mm and in
RPM vs Speed
-Input Tire Diameter/Rear end ratio/Transmission to get your speed in any gear
-Has pull down menu for many popular trannys or you can add your own
-Shows speed in all gears at all rpm
Cam calc
-Input cam durrations to calculate valve overlap
Valve Spring Calc
-Input Valve spring parameters to see pressure created
-visual aid for picking a spring and adding spacers
Pipe Sizes
-Chart of cross sectional area of pipes, single and dual
-Helps determine if you want a single 3.5" exhaust or dual 2.5"
This spread sheet comes in an Excel file. If you shoot me a pm with your email address I'd be happy to ship it on to you. It the least I can do for all the people that have helped me on this forum.
Old Nov 9, 2007 | 07:52 AM
mn_vette's Avatar
mn_vette
All emails sent out. If I missed someone please let me know.
Old Nov 9, 2007 | 02:01 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I'll take one please.
teamsfr@bellsouth.net
Old Nov 9, 2007 | 02:14 PM
MotleyDrew's Avatar
MotleyDrew
Guys and gals,
Here's what it has:
RPM vs Speed
Cam calc
Valve Spring Calc
Pipe Sizes
I will take one !
thanks for your hard work !!!
drewcameron@rogers.com
Old Nov 9, 2007 | 03:31 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
sounds cool
wreid001@comcast.net
thanks !
Old Nov 9, 2007 | 03:35 PM
rapid robert's Avatar
rapid robert
Thanks for sharing
rpmoore9@comcast.net
Old Nov 9, 2007 | 10:50 PM
hawaiiC5's Avatar
hawaiiC5
St. Jude Donor '09
would like a copy, thanks in advance
areada@gmail.com
Old Nov 9, 2007 | 11:06 PM
NOS500's Avatar
NOS500
I'd like to have it.
rrudshagen@socal.rr.com
Thanks a lot!
Old Nov 10, 2007 | 10:55 PM
Gideon's_Test's Avatar
Gideon's_Test
PM Sent
Old Nov 11, 2007 | 12:02 AM
Sick Z06's Avatar
Sick Z06
PM Sent as well!
Old Nov 12, 2007 | 04:22 PM
mn_vette's Avatar
mn_vette
TTT, anybody else?
Old Nov 12, 2007 | 04:56 PM
Sick Z06's Avatar
Sick Z06
Thanks man, Good stuff!
Old Nov 12, 2007 | 06:27 PM
87SAM's Avatar
87SAM
I'd take a copy! Looks to be very handy, thanks for the hard work
BTW - I grew up in South Lyon (many, many years ago)
00frc@clearwire.net
Old Nov 12, 2007 | 06:32 PM
danberry's Avatar
danberry
I would also like to have one...Thanks In Advance danb00c5@yahoo.com
Old Nov 12, 2007 | 08:35 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I want it too! PM Sent!
Thanks in advance for your hard work, and willingness to share.
Old Nov 15, 2007 | 08:31 AM
mn_vette's Avatar
mn_vette
Well, I've sent out over 50 copies so far. If anybody else wants one let me know.
To Car Calcs, some usefull stuff
