Freeing Up Headlight Adjusters
Old Nov 9, 2007 | 08:42 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Freeing Up Headlight Adjusters
Will be working on my lights this weekend and I want to make sure that the headlight adjusters are freed up and working properly. I know people have broken theirs if they are siezed up.
Are they accessable through the top with the bezel and the top removed?
Also lube suggestion.
The Pup
Old Nov 9, 2007 | 12:29 PM
CTSV OWNER's Avatar
CTSV OWNER
Remove the headlamp assembly. Then you can see how the gears are seized. It was kind of a pain but very fixable.
Dave
Old Nov 9, 2007 | 03:23 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Just look at where everything is when you get things opened up. I used Superlube Dry Lube in a spray can.......worked great
To Freeing Up Headlight Adjusters
