Typical Oil Pressue
Old Nov 9, 2007 | 10:42 AM
weinerschizel's Avatar
weinerschizel
Default Typical Oil Pressue
I noticed my oil pressure guage can read around 3/4 of the way to it's maximum range. Especially when the car is warming up. Is this typical? I don't want to blow any seals out.
Old Nov 9, 2007 | 11:16 AM
vincentjames501's Avatar
vincentjames501
When the car is not warmed up it runs higher. Once at operating temps I would say 40-45 is normal. Note that when you drive it harder the oil pressure rockets up... Which is normal.
EDIT: I wouldn't worry about blowing any seals anyways as I don't trust these oil pressure gauges anyways. They have a tendency of breaking.
Old Nov 9, 2007 | 01:19 PM
Tom73's Avatar
Tom73
what pressure is the DIC showing?
Old Nov 9, 2007 | 02:32 PM
rws.1's Avatar
rws.1
many oil presure sensors go bad...
it is a simple 2 hr DIY fix...
look for a post by vectorz and the key words oil pressure sensor in the archives
Old Nov 11, 2007 | 12:33 PM
weinerschizel
When I get on it... Oil pressure on the DIC says 77 psi. The guy I bought the car from said he installed a LS3 oil pump. Do those tend to run at a higher pressure? At idle the pressure is around 50psi.
Old Nov 11, 2007 | 11:36 PM
Corvette Don's Avatar
Corvette Don
50 psi @ idle? Sounds like a bad sensor to me. Mine is 30 @ idle and 62 psi @ 6k rpms and I have a ported LS6 pump.
Old Nov 12, 2007 | 08:35 AM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
Mine runs 30-35 idle and 45 under normal driving. will jump to 50 under hard acceleration
Old Nov 12, 2007 | 08:42 AM
vincentjames501
Old Nov 12, 2007 | 09:50 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Mine runs about the same on a LPE 383. Cold engine 42 at idle then down to 30 when hot. 61 to 62 at 62k.
Old Nov 12, 2007 | 04:58 PM
dmiz0420's Avatar
dmiz0420
damn, I thought the source of my 97 engine ticking was my stock ls1 oil pump putting out 30 psi idle....
guess I need to look elsewhere.
Old Nov 12, 2007 | 05:11 PM
timemender's Avatar
timemender
If it were a pronounced ticking, I would check the rocker arms as the roller bearings in them can come out and end up in the oil pan.
Accessory belts and also fuel injectors can cause ticking so don't panic needlessly.
Old Nov 12, 2007 | 06:21 PM
Slick Rick's Avatar
Slick Rick
yep, Sounds like your sensor is about to die. Mine did the same thing ,kept getting higher and higer and the one day it pegged to 80............
Old Nov 15, 2007 | 10:36 AM
aris's Avatar
aris
i just noticed this last night...
mine idles at around 35-40 psi, about 40-45 psi under normal cruising around, and if i get on it will get up to 65-70 psi... is that really normal? i feel like i would have noticed that sooner?
Old Nov 15, 2007 | 01:27 PM
Oldvetter's Avatar
Oldvetter
The LS1 only needs 8 psi oil pressure at idle. Having said that, I switched my oil filter from GM DELCO UPF-44 to a WIX or NAPA GOLD (same filter) and my cold oil pressure increased 10-15 psi (the oil sensor is AFTER the oil filter so this is an increase in flow). An oil analysis showed no difference.
To Typical Oil Pressue
