ZEX traction control window switch question???
Old Nov 9, 2007 | 07:43 PM
skydive120's Avatar
skydive120
Default ZEX traction control window switch question???
Hello,
Im installing a ZEX traction control and window switch (PN 82085) this weekend and would like verify something.
The 2000 Corvette is a individual coil per system setup correct (when refering to this units install)??
See below--
STEP 1: TACH signal set-up
Number display B and C should be set to the chart below (Number display A is not used in this step):
0 0 = individual coil per cylinder systems where the TACH wire is connected to the coil
0 1 = coil packs that fire in pairs (waste spark systems) and the TACH wire is connected to the coil
0 2 ~ 1 2 = number of engine cylinders, from 2 to 12, where the TACH wire is connected to the tach from the engine electronic controller or distributor
A link to the full instructions-
http://www.zex.com/Base/Instructions/ZEX169.pdf
Thanks for any info-
Chris
Old Nov 9, 2007 | 08:16 PM
jhong321's Avatar
jhong321
I am running the zex kit as well but a different window switch. Are you looking for the tach signal ? If so you need to tap into the white wire off the cpu (located under the battery) I think it was the #10 wire . You could also try ls1tech.com they will be able to answer all your questions.
Old Nov 9, 2007 | 08:27 PM
skydive120's Avatar
skydive120
Actually I know which wire it is, there is a plug on the right valve cover that has the tach wire signal, and yes, I beleive it is the #10 wire.
Just trying to verify the correct setting for this particular unit, beleive it should be 00 since its a single coil pack per cylinder.
Thanks-
Chris
Old Nov 11, 2007 | 02:03 AM
skydive120's Avatar
skydive120
Anyone?
To ZEX traction control window switch question???
