question about coolant block off/crossover
Old Nov 12, 2007 | 01:13 AM
MJD's Avatar
MJD
Default question about coolant block off/crossover
I'm in the middle of a head swap and wanted to check on this before putting the heads on. On the coolant block offs and crossover pipe there is a gasket. Is it recommended to replace these? If so does anyone have a part number or is it easier to just throw on some RTV sealant. Also, anyone have the torque specs on these.
Old Nov 12, 2007 | 01:23 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
you can reuse the old gaskets and be just fine, but if you don't have any, yes you can use hi temp silicone.
Old Nov 12, 2007 | 01:32 AM
MJD's Avatar
MJD
Damn, that was fast. Thanks a bunch!
To question about coolant block off/crossover
