water pump leaking, which replacement?
Old Nov 12, 2007 | 01:28 AM
MEXAKNPWR's Avatar
MEXAKNPWR
Default water pump leaking, which replacement?
i looked it up on the forum but i am trying to get the information organized in my head.
ok, when i get a replacement water pump, do i need to get a new thermostat and the neck?
if i instead opt for an 04 water pump or ls2 water pump which i read will fit a 1998 corvette, do i need to get a new thermostat and neck?
are there any benefits to geting an ls2 or 04 w.p., do they flow better etc?
thanks in advance
Old Nov 12, 2007 | 01:38 AM
MEXAKNPWR's Avatar
MEXAKNPWR
dumb question, i just saw that the thermostat comes with the housing.
Old Nov 12, 2007 | 03:05 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
According to GM, the LS2 waterpump has had a slight redesign that reduces the replacement interval. In essence, you should NOT have to replace it again. As far as flow, they are the same.
I would just get whatever is cheapest. You can usually find them for around 100-125 bucks shipped. I found my LS2 waterpump for 115 shipped brand new from a guy off of LS1tech.com
Old Nov 12, 2007 | 06:15 PM
MEXAKNPWR's Avatar
MEXAKNPWR
good call, i just got an ls2 pump for 130 shipped when i looked around a little harder.
thanks
To water pump leaking, which replacement?
