Need help, power steering not working....
Old Nov 12, 2007 | 08:23 AM
Falcon's Avatar
Falcon
Default Need help, power steering not working....
We just changed the steering rack with a rebuilt GM rack.
When I tried the car out on the parking lost, the power steering wasn't working. The guys who changed the rack assured me they bled the system per the instructions before they started the car.
I put the car on jack stands and bled it again according to the instructions and still no power assist.
The pump is not making any noise. Any other ideas on what to check?
TIA.
Old Nov 12, 2007 | 01:22 PM
NITRO UK's Avatar
NITRO UK
Hi matey
apart from the two hoses that connect up to the rack shoot what else is there, right! i cant remember if those fittings are the same size.like they may be the wrong way round.in /out and out/in.
and also what made you think it was the rack,and not the pump????if you know where im going.it woudnt be the 1st time someone has fitted
a bad (new) part. hope you get it sorted soon as. nitro uk
Old Nov 12, 2007 | 01:49 PM
Falcon's Avatar
Falcon
Originally Posted by NITRO UK
Hi matey
Oh, I forgot to mention this is a race car. I replaced the rack because it was leaking pretty badly from the driver's side boot. After removing it we discovered the bracket that held the old rack to the cradle was busted off, probably from an incident I had with a wall earlier in the year. That's why the rack was replaced.
The P/S pump is a 1st Turn pump and was just installed in the spring of the year, so I don't think that's bad.
You're right, there aren't that many things that could be wrong, just irritating.
Old Nov 12, 2007 | 01:52 PM
NITRO UK's Avatar
NITRO UK
you`ll get there
Old Nov 14, 2007 | 11:01 AM
spider94r's Avatar
spider94r
It took FOREVER for me to get my rack bled. Literally like 3 hours of turning the wheel back and forth over the course of a few days. Until all the air is out, no boost.
To Need help, power steering not working....
