Rotor Question
Old Nov 12, 2007 | 05:42 PM
Slick Rick's Avatar
Slick Rick
Default Rotor Question
I have some new rotors arriving soon. They are not zinc plated. I dont want to deal with rusty caps so Im going to paint them. I have some dupli-color 1200 degree high heat paint out in the garage. Will that work or should I use somthing else? Thanks........... P.S will brake cleaner remove paint ?
Old Nov 12, 2007 | 05:55 PM
RossJackM's Avatar
RossJackM
Brake cleaner will remove fresh pait. Let the coating "cure" before using cleaner on it.
Old Nov 12, 2007 | 06:01 PM
rws.1's Avatar
rws.1
that should work.. use the brake cleaner to de-grease the new rotors prior to painting.
To Rotor Question
