well, i called arp, did you?? they told me 235 lbs with moly lube. i still have the shrink wrap and the info written on it.
Yes I have, several times. We use their fasteners in many of our experimental projects at work. I have installed several of these particular bolts, have you???
There are also a number of guys who have tightened this bolt to 250 lb-ft based on the ls1howto instructions not realizing that bolt stretch is based on many things other than torque, poor guys ended up replacing crankshafts or trying to drill out the pieces. If you want to use 235, feel free. If I were in your shoes, since you don't want to believe what several have told you here, call ARP again. This time ask for the head of tech.
so should i still use the old bolt to torque the balancer down to 240 ftlb then back it out and torque the arp bolt dowm to 190?
Yes, follow the GM procedure until you get to the part about installing the new bolt. Don't lube the crank threads when you use the old bolt, or you will need to decrease the torque value accordingly. Lube the ARP bolt, washer and head when you install and run it in and out by hand a couple of times to lube the threads.
Bringing this old thread back with an update...The instructions that came with mine say 235, so that's what I plan to do. ... right?
Yes, as long as you use their lube (in bold in the instructions). That lube didn't exist when this thread was started. Not sure if there weren't other changes to the bolt itself, only ARP would know that. Torque is used to measure bolt preload/stretch, so changing the lubricant changes the friction and changes the torque value used to measure. Friction is the most important factor in accurate bolt preload determinate when using torque as the measuring tool.
