underdrive balancer
Old Nov 13, 2007 | 09:47 PM
bowtiebubba's Avatar
bowtiebubba
Default underdrive balancer
Im reinstalling my underdrive balancer that worked its way out about a 1/4 inch. Does the balancer when all the way on, set flush with the end of the cranshaft? Thanks,Guys
Old Nov 13, 2007 | 09:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Should be about 1/8" from being flush with the end of the crank.
When you draw it on with the bolt (or preferably a threaded rod and nut), you should definitely feel when it bottoms out on the shoulder of the crank.
If your old bolt loosened up, causing this, make sure you replace the bolt and don't just re-tighten the old one., or it will happen again.
Old Nov 14, 2007 | 06:19 AM
bowtiebubba
Its not going to happen again,im pinning the crank and going to use the ARP bolt. I dont want to pull that steering rack ever again. What a pain in the butt.
Old Nov 14, 2007 | 06:54 PM
bowtiebubba
I received the arp bolt today.Do i need to put loctite on it before installing?When you torque the bolt,plus the degrees,what do you use to measure the degrees?Is it acceptable to just guess on how many degrees you have torqued? Thanks
Old Nov 15, 2007 | 09:08 AM
bowtiebubba
ttt
Old Nov 15, 2007 | 11:06 AM
corvettebob1's Avatar
corvettebob1
Since you have pinned the crank you have resolved the root cause of the balancer walking off.
Just use lube on the ARP bolt and torque to 180-190lbft and your good to go!
Old Nov 15, 2007 | 11:14 AM
Thickraybans's Avatar
Thickraybans
No thread locker.
Old Nov 15, 2007 | 11:37 AM
vettenuts's Avatar
vettenuts
190 lb-ft with ARP Assembly Lube on threads, washer and under head of nut. This after you have re-seated and followed the GM procedure using the old bolt.
To underdrive balancer
