intake question ls1 vs ls2
Old Nov 14, 2007 | 04:16 AM
luckyone928's Avatar
luckyone928
Default intake question ls1 vs ls2
i have an 02 ls1 and need an intake, what will be the gain in putting an ls1 on it?
Old Nov 14, 2007 | 06:14 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
You already have an LS6 intake manifold (I assume that its the manifold you are referring to) so what would you need to change?
Old Nov 14, 2007 | 07:58 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Yup, your 01 has an LS6 intake already, LS2 would be a downgrade
Old Nov 14, 2007 | 11:06 AM
travelingypsye's Avatar
travelingypsye
Ok my question is: is a LS2 with a 90 tb better than a stock 99 ls1 intake?
Old Nov 14, 2007 | 12:10 PM
luckyone928
okay, here's the deal-- i bought a 99 w/o an engine-- bought an 02'engine w/o a manifold!! sooooo, the question is should i spend the extra $$$ for the ls2 manifold, find an origional ls6 that came with it or just put an ls1 manifold on it?--what is the difference!!
Old Nov 14, 2007 | 01:18 PM
Former Vendor
Go with an LS6 intake and C5 throttle body, they are just fine up to around 500rwhp
Old Nov 14, 2007 | 02:35 PM
vincentjames501's Avatar
vincentjames501
Get the fast 90
Don't go with the LS1 manifold though for sure. LS6 is still good for mild modded cars.
Old Nov 14, 2007 | 03:02 PM
luckyone928
okay whats the difference between the three manifolds??
Old Nov 14, 2007 | 09:02 PM
ArKay99's Avatar
ArKay99
I would suggest the search. But,a quick synopsis is. Stock C5's from 97 through 00 got LS1 manifolds. 2001 and up got LS6 manifolds. The difference in the LS1 and LS6 manifold is minimal without other mods. But as you start needing more air the LS6 will outflow the LS1 more and more.
The FAST manifold is very expensive and it's fit and finish aren't that good either. They have a tendency to leak, and are easy to break at the throttle body mounts. However, they flow the best of all 3 and with a good h/c combo will give you +10-15hp over the LS6.
As I suggested above, try the search on LS1 vs LS6 and also FAST and you will find way more info than you can get from this post.
Old Nov 14, 2007 | 11:44 PM
Chemdawg99's Avatar
Chemdawg99
Like eurospec1 says, unless you are going for more than 500HP the LS6 intake is all you need
Old Nov 15, 2007 | 11:12 AM
kromberg's Avatar
kromberg
Get a LS6. The FAST is over priced and overkill for you. A LS2 intake performs slight below a LS6 in NA applications.
Keith
To intake question ls1 vs ls2
