MY 2004 vette with 11k miles is in the shop now running up a 10.4 hour labor charge due to the transfer line between the two gas tanks leaking. Got to drop the tanks, rear end, transmission, and also slightly lower and angle the motor to repair it. Has anyone ever heard of this??? My mechanic has tried to get some help from GM but they said NO -out of warranty since it was made in Jan 04.
My 04 had the same leak (gas was a steady stream) 900 miles from home. I heard that GM went to a metal cross over line on 04 cars. I had GMPP cover mine. Kansas City dealer said the tank nipple that the hose was connected to was out of round. I filed a report to NHTSA on this.
Most of the leaks I've heard of are the tank leaking where the crossover pipe hooks up, This is the first time I've heard of the crossover pipe leaking.
By the way, the pipe comes out before the tanks and if the crossover pipe is the only thing that is leaking then there is no reason to pull either of the fuel tanks.
you don't have to pull the tanks but u do need to drop the trans. to remove the cross pipe i have replaced at least 3 fue pumps on 04 and that is the only way to disconnect the pipe for reapairs unless someone has very small arms and can just lower the trans. down to get it
I think it is actually leaking at the connection on the left tank.
This is where mine was leaking and it turned out to be the tank. I pulled the tank and everything looked good but I decided to replace the tank before I would replace crossover pipe and the new tank fixed the leak.
I have done numerous repairs on these, the automatic trans are more difficult to gain access. The manual trans make the crossover replacement a snap. The book time is right though. For a side job I would charge $300 plus the parts.
I remove the mufflers, rear sway bar, vent solenoid and thats it to replace the crossover
Thanks to everyone for your help. I plan to file a report to NHTSA and have taken numerous pics. GM has refused to cover under warranty and refused to admit that there is a problem with their mickey mouse connection design between the tanks and the transfer line connector.
my 04 leaked too, covered under warrantee at the time. I was told it is the o-rings on the connector to the tanks, but the preferred way to fix was to replace everything just in case...because considering the labor, they wouldn't want to do it a 2nd time.
I also heard that putting additives in the tank and NOT IMMEDIATELY WASHING IT DOWN WITH A TANK OF GAS can mess up those o-rings and cause a leak.
The 04's had some bad fuel tanks in the supply line. The Cadellac XLR's and 04 Vettes were affected. Once your driver's side fuel tank is replaced you won't have a problem. The tech that worked on mine reported that he could feel the difference when the crosstank feed tube snapped into place on the new tank. They thought it was the o-rings at first too, until they had to do it again. I don't believe that it's the additives affecting the o-rings. I do believe that there was a faulty tank design.
the more i think about it, it is quite unfair that the dealer won't cover it. Try another dealership, talk to the top guy, be sweet as sugar. I can't imagine they would turn away a car with 11k !
Be creative. Their business is based on relationships. Try. Maybe if he sees that your regular dealership did not satisfy you, perhaps he can grab onto you as a new customer and maybe your next purchase will be with his.
- Wisdom
You can report this to the NHTSA if you want but they won't be able to do anything, GM will show them that they built approx 35,000 of these every year since 1997 and then be able to say they've only seen XX number of failures (probably less than .1%), granted all of the leaks I've heard of were early 2004 models and they were all left side tanks.
There was a redesign for 2004 and that caused the problem. This needs to be stated to NTSA.
I just picked up my car after having all crossover gas lines and o rings replaced on both tanks. The o rings on the lines tying into the left tank were bad. Major job, but I was now relieved. I then parked it in the garage and was getting ready to reset all the electronics and re-detail it when I noticed that gas is leaking in the same place AGAIN!!!!!! It sounds like I should have had them replace the left tank also. HELP!!!
The more I think about, I think your absolutely correct, this way if the Government makes GM issue a recall I might get reimbursed for my fuel tank, this is the only reason I'm not going to throw the old fuel tank away.
BTW - the actual fuel system change happened mid year of the 03 model, I think around November/December 2002 but for some reason all of the failures I've heard about were 2004 cars, GM must have made a supplier change or the supplier made a manufacturing change???
Tank flange for crossover was out of shape on mine. Find a dealer that has a lot of Vettes on his lot. Talk to SERVICE MANAGER only. He can give you a GM GOOD WILL repair for a new tank.
