Maximum depth you can fly cut ??? Crap !!!
Old Nov 14, 2007 | 11:22 PM
brian vette's Avatar
brian vette
Default Maximum depth you can fly cut ??? Crap !!!
Anybody know the maximum depth you can fly cut a stock piston. I have heard .120 but I cut one to .164. Not planning on nitrous ....so am I safe or shall I worry from now on out Crap!!!! Thanks
Old Nov 15, 2007 | 07:28 PM
Greg_E's Avatar
Greg_E
Brain,
Here is the thread where it was mentioned that LG recommended a max cut of .080".
http://forums.corvetteforum.com/show...hlight=fly+cut
If you don't get any other replys here, try the LS1Tech forum.
Old Nov 15, 2007 | 07:39 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I've seen preople cut up to about .140" deep successfully.
There is about 1/4" (.250) meat on the piston top. You might be ok, just make damn sure you never run lean!
And serious, it's time to put the drill down and use something a little slower, ie: tap wrench or air ratchet. (those notching tools were actually designed to be used by hand).
Old Nov 15, 2007 | 10:00 PM
brian vette
Default Fly Cutting
Okay Guys this is what I found out. The actual piston thickness is.360. and one guy actually measured it to be 8 mm. The cut I made is .164 the rest .120 intake, that gave me clearance of .085. Exhaust .125 for a clearance of .100 So maybe it will be alright. Great tip about running lean . Start up in 2 days so then we will see Thanks
Old Nov 15, 2007 | 10:28 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Now I'm really surious to know what head/cam specs you're running to get those numbers.
Old Nov 16, 2007 | 09:14 AM
brian vette
Default Cam
MS4 651/612 240/248 111 lsa TSP 5.3 59 cc chambers milled .030
To Maximum depth you can fly cut ??? Crap !!!
