Wiring gurus, step inside!
Old Nov 15, 2007 | 05:53 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Wiring gurus, step inside!
Next week I am going to start with my head swap. At this time I will be also upgrading my fuel system. I bought a Kenne Bell Boost a pump and the racetronix harness and I only want the boost a pump to come on when I activate my nitrous system through the switch on my switch panel. How would I go about wiring this?
Old Nov 15, 2007 | 08:00 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I would think the easiest way would be to replace NOS switch with a "double pole single throw" switch. Wire the NOS to one side and the KB BAP wiring for the vacuum/pressure switch to the other side.
Very easy, simple and foolproof.......
Old Nov 15, 2007 | 08:51 PM
Corvette-Chris
St. Jude Donor '08
Sorry for stupid questions but me and wiring dont get along to well haha
What is a double pole single throw switch ?
Old Nov 15, 2007 | 09:28 PM
*C7*'s Avatar
*C7*
It is just a switch with four lugs and two positions ( ie one position of the switch is off = contacts open and the other switch position is on = contacts closed. There is no electrical connection between the two switches.
The switch for your NOS is most likely a single pole-single throw..
The double pole acts just like 2 separate switches built into one switch.
Old Nov 15, 2007 | 09:30 PM
Corvette-Chris
St. Jude Donor '08
Where can I get this switch?
Edit: I just found examples and I know what you mean now. Now I just gotta figure how to wire it haha
Old Nov 15, 2007 | 10:26 PM
*C7*'s Avatar
*C7*
Just wire your NOS to one side of the switch and wire the BAP vac/pressure switch wire to the other side. The wires will proably be red and black and they can be hooked up either way, it makes no difference as the switch is just connecting the two.
Your new "DPST" switch will replace the vac/press. switch...
Boost on demand.
Old Nov 15, 2007 | 10:52 PM
Corvette-Chris
St. Jude Donor '08
So my Nitrous activation to one side of the switch and the BAP to the other? And....The racetronix harness from the alt. to the fuel pump and BAP and the BAP pressure switch to the Arm switch of the nitrous system? If that it, it doesnt seem to hard
To Wiring gurus, step inside!
