Mods That Work !
Use a set of 3.42 Gears and you'll be in the 12's
Use both together and you'll be in the 12's although you will be lower in the 12's than using just one of the two only!
You will only need a handheld tuner to change either of these two or both together for the PCM to accept the new changes!
Thanks,Matt
Plus 15 RWHP, Plus 21 RWTQ max,,,,I can promise you will feel that
91 octane conservative tune and base and modded dyno runs on the same Mustang Dyno!
LG > Ti = LS6 intake > 160 thermo.
Did the thermo when I did the water pump just because I had everything apart... and because I got a little preignition during 100F days. It won't take the car any longer to warm up, it just won't get as hot when it does... and it's pointless to run it without programming your fans unless you're on the highway.
I'd say I was at about 385ish FWHP; it was exactly as fast as my '01 and when I corner weighted it, it weighed about the same as the Z06's for whatever reason. FWIW, both cars had full tanks, and since the other driver was myself... well the drivers weighed the same, too.
Suffice it to say that when lined up, neither car moved more than a foot with respect to the other from 40ish to 110ish (on the closed course, of course). Guess I need to remove the '97 from my sig... sold it a couple weeks ago
Is this the Predator ? I know it has an advantage over the Hypertech in that you can program your car for gears above 3:15 ! I heard hypertech won't do it for 3:42's and up!
I know you can change maps, program.. this that .. but if you can
tune it with the mods and pull that much HP, that's awesome !
you probably could pull 30ish RWHP ?
Thanks,Matt
1/4 mile 13.27 @ 107.1 G-tech PRO 13.34 @ 106.9 ( ~ .05 to a tenth difference between the 2 is normal because the track measure's when you cross the laser, the g-tech, as soon as it registers .1 g's...basically as soon as the car moves).
0 - 60 4.87 secs
0 - 100 11.23 secs
60' 2.20 (that blows... my best was like 2.18)
Stock 2000 A4 2:73 gears, 59 degrees outside.
Stock tires, 28 PSI rears, 30 PSI Fronts. Still spin a little, but just enough to get a good 0 - 60 time. Spin any more, then i'm doing 4.9 ~ 5.06 sec.
I know when i had my Z, stall converter and drag radials, I took 1/2 second of my time (mainly do to a much improved 60'). from 13.50's to 13.00s. Probably would had dipped into the 12's if i got a real good launch!
Intake
Headers
if you have an Ls1 put on an Ls6 intake manifold
Cam
Thats what I am doing little by slow, the Cam and intake made 57 HP but took away a lot from the low RPM range hence the headers, and LS6 manifold and tune I should easily be over 400HP with those mentioned mods. After that it's a good idea to change the clutch and think about wider rear tires.
At the end of the day the best mod to make is a better driver
Intake
Headers
Cam
Which cam you going with ?
upload for your mods ? They make the Blackwing, so it seems to be
a nice package...
This seems to be a nice package, but not sure about it...
http://www.mamotorworks.com/corvette-2-135-6641.html
Does relocating the MAT sensor to supposedly sense cooler temps in conjunction with using the tuner really work ? According to everyone .. NO! Waste of Money.
Now I heard good things about a ported and polished TB. Recommended by forum members.. >>> http://www.s2performance.net/vettepage.html
Little better bottom end, better response ... so this seems to worth it !
10% of normal ls1 cars had ls6 blocks in 2001
25% of normal ls1 cars had ls6 blocks in 2002
At least this is the figure for F-bodies. They still had the same heads, camshaft, and other parts, and made the same hp as ls1 block cars
So these claims you'll get 8 ~ 10 HP with a larger MAF that's recalibrated...hmmm doesn't work !
http://www.zainostore.com/Merchant2/...oduct_Count=19
something no corvette owner should be without !
